1 - 2 of 2 Posts
Hy guys I need a help with this problem
My nox sensor I (before SCR) show up to 400ppm and nox II (after SCR) up to 900ppm that makes no sense to me... Pls help it shows adblue system failure on display
I'm not an expert but it sounds like you have to fix your scr. It sounds like you have buildup that is not getting burned off. I have seen some videos where they clean the scr through a hole in the scr but have never done it myself.
If you have to do an expensive repair, you might consider a full delete instead.
1 - 2 of 2 Posts
