1 - 3 of 3 Posts
okay. yesterday i started my car after work. and when i put the windows down, one stopped 1/8 from the bottom. then i noticed that my obc was off and my aftermarket alarm didn't work either. i also have the automatic rollup windows when the alarm is amred. so it seems like all of a sudden i lost power to my obc and alarm.... any ideas? :cry:
Still here
would normally say it would be a fuse, but i doubt they are all on the same circuit.
Could be that an earth strip has worn away or some shielding on a main wire has worn away and it shorting out.
Am pretty sure the OBC and windows are on seperate circuits so would check the Main fuses in the engine bay first and then the wires themselves. (normally on the top right of the engine bay as you look at the car from the front)
Hope this helps
1 - 3 of 3 Posts
