Status
Not open for further replies.
Official F10 Coding thread---Exploring Your F10
785K views 1.5K replies 94 participants last post by  DreamCar
#1 · (Edited)
I hope this will be the most intriguing thread!
We will discuss all the options available and try to share as much information as possible .
Knowledge Transfer: Find the attached pdf in the below link and go through it ... It will give you the basics to start also check the attached PDF (Thanks to modular93 fox)
http://www.bimmerfest.com/forums/showpost.php?p=6823380&postcount=6 (If the link doesnt work go to post # 6 in this thread)
How to make the Enet cable (You need this cable to connect your car and you laptop), Its not hard to make your own cable.
It would cost around 10 to 15$ to make a cable.
Please use the below link to find the detailed description on how to make your cable (Thanks to IMSw1) and also check teh attached PDF for detailed schematics
http://www.bimmerfest.com/forums/showpost.php?p=6825214&postcount=52 (If the link doesnt work go to post # 52 in this thread)
List of things that can be programed: (Thanks to All contributing Members)
Please check the Cheat Sheet for the list
Data Files Required to code your car:
F001 psdzdata covers the F01/F02/F04 7-series and F07 5-series
F010 psdzdata covers the F10 5-series and F12/F13 6-series
F020 psdzdata covers the F20 1-series and F30 3-series (There is no Z4 F-chassis yet)
F025 psdzdata covers the F25 X3-series (There is no X5 F-chassis yet).
More details in the below Link:
http://www.bimmerfest.com/forums/showpost.php?p=6827272&postcount=91
Cheat Sheet:
What Module to modify.. What Parameter and What value will be explained in the attached cheat sheet... This will have all our new discoveries going forward.
This thread is dedicated to help fellow festers! Will add more details as and when available just follow the thread for updates!
Volunteers: People who can install for others /Willing to help others with installation
1) DreamCar (NJ,MD)
2) Shawnsheridan (Houston,TX)
3) Imsw1 (Dayton, OH)
4) Svache (Oahu.HI)
5) hd750Li (DFW, TX)
6) wdimagineer (MD)
This is just the basic info... Will add more info in next two days
All the credit goes to Sean and Shawn
Disclaimer: Try it/use it/ request it at your own risk and blah blah and all that cra*P.......
Important: Please dont use "Quote" when replying... In that way it will be less cluttered and easy to browse once it is sticky... :thumbup:
Sub Threads:
SLI :http://www.bimmerfest.com/forums/showthread.php?p=6863231#post6863231
For the video lovers here is teh feast:
http://youtu.be/1dzvhZggafg
http://youtu.be/HdgecnfqoDg
Transfering your phone ring tone to your car.
Before
http://youtu.be/EG4MR-o1eSg
After
http://youtu.be/WuLUgAGypfw
#626 ·
Shawn,
I ran the calculation and it shows the changes to be implemented but surprisingly it doesnt show any changes to KAFAS but shows changes to almost 90% of the modules...
Its is little scary to run the code it is touching all safety modules etc:-
#627 · (Edited)
@ Dreamcar
Lol...I am still new at this and unfortunately I dont have a F series to try out everyday and code and test on it, as I dont own one..:(. I just code for people that want F-series coding. I was just asking as this thread is about learning how to code an F-series, and with coding you also need to test how to convert things back to default if problems arises. I know you can write down all the coding changes you made and revert them back to how it was originally, but again this is for those that screwed up bigtime and cannot go back to original.. I guess at this point this thread is about only discovering new features but doesnt worry about having to code back to default when problems arise. I guess this will have to wait till all the disovery of functions has reached it plateau and there is not too many things to discover anymore
#628 ·
@Erregend;
I think you are correct. I was confusing BC_V_KORREKTUR with BC_DIGITAL_V_KORREKTUR, the latter I did not see in KOMBI. The E60 had both as follows:
BC_V_KORREKTUR = Correction for Analog / Head up display speed
BC_DIGITAL_V_KORREKTUR = Correction for digital speed
BMW can advance the speedometer by 10% + 2.4 MPH per the attachment, which at higher speeds can be pretty substantial. It would be nice if someone with a Radar Gun could actually test an F10 at 100 MPH, and see if its actually closer to 87 MPH.
@alex_c;
Thanks, but my Blackberry is already set to download the full message, so I am not sure what is going on. I'll have to play with it some more.
Save
#629 ·
@DreamCar,
I take it you ran the FP calculations, but that was as far as you went with it, or did you apply it to VO coding to the whole car? My guess is KAFAS is not changing, because you have already manually changed everything in there needed for SLIS. :D It will be interesting if you could restore your KAFAS file from JEG23 after he pulls his, and then change the VO and recalculate it and see then if KAFAS updates. It does seem odd though that so many other modules would need to be coded just for 8TH, but I really don't know if that is normal or not.
Save
#631 · (Edited)
Shawn,
This is what i did
conected---Read VO---Read VCM--Activated FA---clicked "Calculate " button under KIS/SVT section...
and i even see new modules getting added .. i dont understand why would the DSC need to be changed? i am assuming that it checking if there are any new CAF avaialble and my current files are older than version 46? Looks like on what daten files we have
Hans I didnt forget about you i was checking this VO cding offline will get the files for you now... What CAF's do you need?
#693 ·
Hmmm.
Same exact error?
I had turned off the fan and radio, but the door was open (to facilitate cable) and the DRL's were on. Maybe try to turn them off and shut the door?
Worth a shot, but I'm not hoping for much.
Save
#699 ·
I think it is not battery drain/voltage, but noisy environment that killed mine for the time the charger was connected.
You may want to try:
1) running laptop on battery only while coding. (No power line or charger noise.)
2) grounding pins 4&5 to earth ground and grounding metal of computer and grounding the car itself.
3) make sure that one pair if twisted wires in cable are on pins 1&2 and a pair is on 3&6. Twist is critical for noise isolation.
#644 ·
8TD! Looks like we need an new module all together in that case we need all his cafs that will clear the air... Yesterday when I was playing with VO I saw a module coming in.
Mobil when you have some time can you please send us the cafs will pm you my email.
#647 · (Edited)
guys, help me understand how to code a new VO
in Editors&Viewers -> FA-Editor -> Load FA -> Expand FA -> Edit options -> Click the little button to apply changes -> save FA -> calculate FP
in Expert mode
Load the modified FA -> Activate FA
SVT Actual -> READ VCM -> Save SVT
KSI/SVT Target -> calculate -> save SVT
select modules in SVT Tree -> Detect CAF for SWE -> select the module for my I-step -> click OK
after doing this for all modules, I have some of them that contain red CAFS, some that contain blue ones all of them with the green checkmark
Here I'm stuck,
After doing all of this, should I click code for all of them, or just for the blue ones or just for red ones.
Status
You have insufficient privileges to reply here.
