Status
Not open for further replies.
Official F10 Coding thread---Exploring Your F10
785K views 1.5K replies 94 participants last post by  DreamCar
#1 · (Edited)
I hope this will be the most intriguing thread!
We will discuss all the options available and try to share as much information as possible .
Knowledge Transfer: Find the attached pdf in the below link and go through it ... It will give you the basics to start also check the attached PDF (Thanks to modular93 fox)
http://www.bimmerfest.com/forums/showpost.php?p=6823380&postcount=6 (If the link doesnt work go to post # 6 in this thread)
How to make the Enet cable (You need this cable to connect your car and you laptop), Its not hard to make your own cable.
It would cost around 10 to 15$ to make a cable.
Please use the below link to find the detailed description on how to make your cable (Thanks to IMSw1) and also check teh attached PDF for detailed schematics
http://www.bimmerfest.com/forums/showpost.php?p=6825214&postcount=52 (If the link doesnt work go to post # 52 in this thread)
List of things that can be programed: (Thanks to All contributing Members)
Please check the Cheat Sheet for the list
Data Files Required to code your car:
F001 psdzdata covers the F01/F02/F04 7-series and F07 5-series
F010 psdzdata covers the F10 5-series and F12/F13 6-series
F020 psdzdata covers the F20 1-series and F30 3-series (There is no Z4 F-chassis yet)
F025 psdzdata covers the F25 X3-series (There is no X5 F-chassis yet).
More details in the below Link:
http://www.bimmerfest.com/forums/showpost.php?p=6827272&postcount=91
Cheat Sheet:
What Module to modify.. What Parameter and What value will be explained in the attached cheat sheet... This will have all our new discoveries going forward.
This thread is dedicated to help fellow festers! Will add more details as and when available just follow the thread for updates!
Volunteers: People who can install for others /Willing to help others with installation
1) DreamCar (NJ,MD)
2) Shawnsheridan (Houston,TX)
3) Imsw1 (Dayton, OH)
4) Svache (Oahu.HI)
5) hd750Li (DFW, TX)
6) wdimagineer (MD)
This is just the basic info... Will add more info in next two days
All the credit goes to Sean and Shawn
Disclaimer: Try it/use it/ request it at your own risk and blah blah and all that cra*P.......
Important: Please dont use "Quote" when replying... In that way it will be less cluttered and easy to browse once it is sticky... :thumbup:
Sub Threads:
SLI :http://www.bimmerfest.com/forums/showthread.php?p=6863231#post6863231
For the video lovers here is teh feast:
http://youtu.be/1dzvhZggafg
http://youtu.be/HdgecnfqoDg
Transfering your phone ring tone to your car.
Before
http://youtu.be/EG4MR-o1eSg
After
http://youtu.be/WuLUgAGypfw
#1,236 ·
@cn555ic;
Well, it's too early to tell really if it's all F30's. He could be the exception like @mjgood seems to be with the F10, who also can't get the Fob working, whereas CA is working fine. More F30 testing is needed. And why there seems to be these rare exceptions in cases like this and TPMS makes absolutely no sense.
Save
#1,237 · (Edited)
@sharbot: Yep, I think I tried it up to half a minute, but nothing happens with the keyfob. Closing the mirrors was also in a different function and not included in the function as it is with the F10 so I'm guessing it's the same with the keyfob (it also only mentions comfort closing but no key).
I am aware about the reason why they didn't make this automatic but what I meant mainly is that I think that we should have an option in our menu where we can select to have it automatically closed. I know others have freezing conditions but we don't have that so much here in HI :)
@cn555ic: I think I mistyped myself there.. what I meant to say is that I needed to do something different in order to have them opened after they were locked by comfort closing (meaning the handles).
In the F30, to close them it is the following function:
FEM_BODY - 3110 PfExternalMirrorMaster - ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
To open I had to enable this function:
FEM_BODY - 3110 PfExternalMirrorMaster - ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
For some reason they don't automatically unfold if you do not enable the latter one :)
edit: and then I noticed Shawn already answered this question haha
I agree with Shawn that we indeed need more people testing these functions. Thankfully several of the F30 owners on that other site already got their cable and are downloading the software so I hope to confirm whether or not it is the same for them when they work on it :)
One thing that is possible is that it is different for mjgood and myself because maybe we have a certain option on our car that others don't have? I wouldn't know but I'm sure we'll find out :)
Save
#1,238 · (Edited)
Hmm I think I found the setting what prevents us from using the keyfob but I am not 100% sure.. but it would make sure, the description is: "komfortschliessen über funkfernbedienung (FBD)aktiv: erlaub nicht_aktiv: niemals möglich, auch nicht im Nahbereichcomfort closing over remote control (FBD). The setting is current at nicht_aktiv, which would make it seem as if the keyfob is not activated for comfort access closing, making it impossible to fold the mirrors (since the mirrors folding is part of the comfort access).
This setting is to be found in my cafs under FEM - 3053 PwMaster - KOMFORTSCHLIESSUNG_FB
I am unable to test this for now but anyone any thoughts on this?
edit: I just noticed that this is actually listed on the F10 cheat sheet as the power window and moon roof closing through keyfob but that doesn't make sense to the description given.. is it possible that you guys had this enabled BEFORE you had the ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN function enabled? Could anyone test this by setting KOMFORTSCHLIESSUNG_FB to nicht_aktiv and then see if the mirrors still fold by using the keyfob?
Save
#1,239 ·
I have key fob enabled for mirror, sun roof and window cliose/open. My car is coded that way from factory.
Meaning if you guys want me to check what my code setting is, pls just send me a list of variables to check?
Mine is F07 as opposed to F10 but should be the same.
To answer some of the question asked before, my 3rd button open the small hatch while my 4th button open the big hatch. I am still struggling in finding the variable to change the inside switch to open the big hatch.
#1,240 ·
Actually I like to ask, can some one please teach me how to use esys to program a part so that it can be used for the car?
Specifically say if a module is broken and we need to replace, how do we program the module so that it can be used for the car without getting an error code?
I currently have my CID that is registering an error code in ISIS/D because it isn't coded for my car!
#1,242 ·
@ello888..
TAL-Processing under Expert Mode is where you program an ECU, you will first have to create a TAL file, which is done under Comfort Mode | TAL-Calculating....
Once you load the TAL file you will be able to see what can be done to an ECU (a lot !), but I haven't found instructions yet that detail the process.... ISTA-P is probably the best/safest way to work with ECU's in this regard..
I'm considering getting ISTA-P and the ICOM Emulator (a physical ICOM is very expensive) which both run in VMWare, so I can work with the car in a more guided fashion.....
Save
#1,244 ·
@mjgood;
So, you are saying:
KOMFORTSCHLIESSUNG_FB = Closes mirrors + windows + moon roof through Key Fob
Then, does this also control the mirrors, albeit for CA?
KOMFORTSCHLIESSUNG_PA = Closes windows + moon roof through comfort access
And if so, what exactly is this doing?
I can't test at the moment, but I am updating the Cheat Sheet, and would like to have this clarified if possible.
Save
#1,245 ·
Just tested settings.....
KOMFORTSCHLIESSUNG_FB aktiv, closes mirrors, windows, moon roof via key fob
KOMFORTSCHLIESSUNG_PA aktiv, closes mirrors, windows, moon roof via CA
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN needs to be aktiv otherwise key fob and CA don't work
note: KOMFORTSCHLIESSUNG_PA was defaulted aktiv on my car......
Save
#1,246 ·
@mjgood,
Thanks. Just so I am clear, ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN by itself does nothing, yet if it is not set to aktiv, neither KOMFORTSCHLIESSUNG_FB nor KOMFORTSCHLIESSUNG_PA will work?
Save
#1,248 ·
@cn555ic,
Yes, I understand that. My question though is specifically about ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN, which mind you is in the FRM module and not the CAS Module.
Save
#1,251 ·
@mjgood,
Amen on the BMW Coding Bible! They have to have all this documented...hopefully it will leak out one day.
Save
#1,257 ·
F07 Hatch Functionality (& F11's)
@All F07 Owners (& F11's) (i.e. @ello888; @1STBimmer; @dmunz; etc.)
Folks, help me understand the coding of the F07 Hatches as it relates to the dash button(s) and fob buttons. To that end, I would like to complete the attached Grid and examine what is common, and what differs in the coding as it relates to your current functionality. Thanks.
Save
#1,288 ·
Here is what I have
CAS -- 3002 CLM -- REMOTE_KEY_SPECIAL_FCT -- aktiv/Werte=01
CAS -- 3002 CLM -- REAR_SCREEN_IS_PRIMARY -- aktiv/Werte=01
CAS -- 3002 CLM -- OPEN_RSCR_WITH_REMOTE_KEY_SPFN -- nicht_aktiv/Werte=00
CAS -- 3002 CLM -- OPEN_RSCR_WITH_PUBU_A_PILLAR - aktiv/Werte=01
HKFM -- 3010_HKLBEDIENUNG -- SCH_FBD -- aktiv/Werte=01
HKFM -- 3010_HKLBEDIENUNG -- SCH_TOEHKI -- nicht_aktiv/Werte=00
HKFM -- 3010_HKLBEDIENUNG -- TASTER_FBD --nicht_aktiv/Werte=00
One thing, I do not have USE_FBD4 in CAS. mine is in HKFM and here is the parameter for mine. assuming it is the same?
HKFM -- 3010_HKLBEDIENUNG -- USE_FBD4 -- aktiv/Werte=01
Rather off topic from this boot thing. for the Air Con, if anyone wants your A/C to remeber to stay off when you powered it off last time you turn off the car key, here is the parameter:
IHKA -- 3000 IHKA_Codierdaten -- OFF_MEMORY -- aktiv (My Original was Nicht_Atkitv)
#1,258 ·
WTF? PM's are limited to 5 people...:tsk:
Save
#1,259 ·
H-Town Coding Meeting / Session
FYI. I just out PM's to 10 users from Houston that have expressed interest in getting together, which I am trying to setup for this Sunday.
If you did not receive a PM, and are interested, please send me a PM.
Save
#1,265 ·
@svache;
I don't think so. @mjgood checked it a few hours ago, and the doorhandles (Comfort Access) were KOMFORTSCHLIESSUNG_PA and the Fob was KOMFORTSCHLIESSUNG_FB, and for either to work though, ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN had to be aktiv, but enabling it by itself alone did nothing.
Save
#1,266 ·
@Shawn: You're right, thanks for clearing that up with me. I never really considered the _PA one as being the one for the door handles :)
Save
#1,269 · (Edited)
Did you add the path to the EST token under Options->Settings (as per the install instructions contained in the download)?
Save
Status
You have insufficient privileges to reply here.
