1 - 9 of 9 Posts
Hey all,
I came across a sweet deal on Craigslist for a set of staggered 22" Giovanna Dalar 5 wheels. I'm close to buying them but not 100% sure they will fit without rubbing on my 2006 750LI.
Here are the specs:
Rim Width: FRONT 9, REAR 10.5
Rim Diameter: 22
Offset: +30
Bolt Pattern: 5x120
Hub Bore: 72.62
The front tires are 265/30R22 and 295/25R22 (but would love to run a 285/30R22 on the rears).
Any help is greatly appreciated!
sounds like all the specs are correct. cant u do a test fit?
Discussion Starter · #3 ·
Hey thanks for the prompt reply 1bad540. Test fitting them would be optimal but being how this is a potential Craigslist deal, I'd like to err on the side of caution and complete the transaction quickly (I've had issues with buyers/sellers from Craigslist in the past).
Also, do you think 285/30 would work on the rear wheels? Or stick with the 295/25's?
295 is fine. keep in mind most 22's are bent and most of the reason for a sale. It would be ideal to have them meet u at a wheel place and have them spun. That said I have seen the dalars onlne for 1200 for a set new so for under 2k you can have new ones with new tires. Vs used and most likely bent and in need of tires. Just a thought. What state are u in? I have my mint 21" 128's for sale with new tires.
2k with new tires and sensors. I have them listed in the classified w pics.
Ill be honest I have no idea on offset. I can check the back of my 128's if you really need. off hand I don't know.
1 - 9 of 9 Posts
