Modern engines running on fully synthetic like the G30 are perfectly fine at 10k miles. Changing oil every 1K miles like OP is claiming is a waste so is 5K miles. People just pull out random numbers on when to change oil. Apparently BMW is wrong, but random intervals from habits built up decades ago on different engines and different oils is correct. Might as well change the oil before every drive 🤣…
I have yet to see a blackstone oil analysis that the 10k interval on these cars is incorrect and more frequent changes are needed.
But it is your money to waste how you please.
So I disagree but that’s perfectly fine! I’d like to present my evidence as mostly anecdotal but leaning towards the intervals being too long. I’d like you to consider the possibility and happy to try and sway you if I can.
B engines are seeming to have fuel dilution issues and sludging IS being seen in the oil filter caps with my own eyes.
I was hoping for a place for people to post B46 engine blackstone reports. Please do not post engines other than B46. If this works there’s no reason not to start a similar thread for other engine variants. My goal is data about how this engine wears and operates and specifically how this BMW...
www.bimmerfest.com
BMW is very up front about lifetime fluids but that just means they are manufacturing vehicles to last 100k as that’s what’s considered lifetime. A quick example is ZF transmission are lifetime full but ZF themselves state that the fluid needs changed. When you combine this with BMWs past history of engine problems you might start to form the picture that oil intervals may be pushing the limits of protection for the trade off of cost management and CAFE.
The earliest I personally can remember is M54 which either dies by being overheated or the “rings go” but the “rings going” is actually a failure of the oil control ring caused by improper lubrication over time which wears the rings and scores the cylinder walls.
The next good example is the notorious N63 which BMW themselves have shortened the intervals on AFTER THE FACT as well as changing the oil quantity going in the engines not to mention the countless engines being replaced for low compression which again is directly related to lubrication and heat management.
The next one is the notorious N20 which suffers from stretched chains, failing guides and wear on the oil pump sprocket causing whining noise. Many people think the chain slack causes the while but they are incorrect. While it’s not good the oil pump sprocket wear is the hair dryer noise that’s synonymous with N20 lubrication problems.
The next example is N55 which is known to lock up under extreme cold temperatures or fail shortly after oil changes or oil related repairs which only occurs on high mileage vehicles and BMW won’t accept responsibility for. They state techs aren’t priming the oil circuit but plenty do get primed and still lock up. None of these issues occurred when N55 was running good old castrol 5W30 but the EPA made BMW remove the zinc and phosphorous due to poisoning catalytic converters. A quick google search will confirm that zinc and phosphorous are the 2 main wear prevention additives in oil but since we can’t use that any more we load it up with molybdenum and additive packages to combat high intervals and oils designed to be a compromise between CAFE, federal emission standards and wear instead of what’s best for the vehicles longevity.
The N55s that don’t die in this fashion normally wind up setting “calculated air mass plausibility” faults which is a measurement of internal drag on the engine ( confirmed with an SIB ) and therefore basically a worn out engine again due to long life and poor lubrication.
B- engines now are great and I’m a HUGE fan but I fear the intervals are again ludicrous as I’m seeing sludge in oil caps, fuel dilution is high on blackstone reports but the KV100 numbers are still robust which basically means sludge. As fuel dilutes the oil it goes from a 0/20 to like 0/15 or less but the reports show oil still maintaining a 0/20 KV100 reading which means viscosity is going up ( sludging or particles added to the oil as viscosity by definition is “resistance to flow” but I ask if oil is being diluted how can it still have the same viscosity? Think about it.
Finally I defer to
@edycol if he doesn’t mind as he worked in oil development in EU and we’ve had many wonderful conversations on oil and I trust his insights.
So again much of this is anecdotal and some of this is hard to prove but the evidence seems to point in one direction. I think it’s cheap insurance to keep my 60k dollar+ ride going by changing the oil more frequently that BMW recommends. There is a possibility that your correct and I’m wasting my money but there’s also a possibly your incorrect. I let history, my experience and the knowledge of others guide my opinions and let’s be honest I sleep better thinking I’m doing the “right thing”.
