synthetic oils and much better control over the ignition system are a couple of reasons why longer oil changes have become the norm. no worries
We've been through this many times before. The same service interval goes for those of us who "rent" (lease) cars from BMW, and I'm sure they wouldn't want to intentionally ruin the engines on the 10's of thousands of cars that they "own" and let us drive at a monthly rental. They do want them back in good condition for their CPO program afterall.All the cars i have driven in the past, i had to change the oil every 6000 miles according to owners manual.....BMW says once a year or 12,000 miles. I find that astonishing. The sceptic in me says BMW recommends this so the car wont last as long and you have to buy a new one sooner. On the other hand i am sure BMW has a good reason for this. Your thoughts?
I'd say you're wasting your $$Yes i can have more oil changes if i want, will this prolong the life of my car? Or am i just wasting money?
Well I care, changed my own oil and I do it once a year (CBS). There is no evidence at all that doing so will lower your engine's durability. There are literally millions since 1998 that prove that it will not.most people that care about there cars will change at no more than 7.5k
Have there been any reported problems with following BMW's 15K oil change interval? I've read some posts where people have had problems around 20K but I haven't read anything about 15K. This might be the wrong place to look as most people seem to change it much earlier than 15K.All the cars i have driven in the past, i had to change the oil every 6000 miles according to owners manual.....BMW says once a year or 12,000 miles. I find that astonishing. The sceptic in me says BMW recommends this so the car wont last as long and you have to buy a new one sooner. On the other hand i am sure BMW has a good reason for this. Your thoughts?
These labs results don't mean much in real life. They will never tell you "everything is in order". They will alarm you for nothing, giving them a raison d'être. They want your business.If you really do have concerns about the service life of the oil, then send a sample in at 7500 or 10K mi for analysis. Do this once or twice and then make the call on whether to follow the computer OC schedule or not.
Below are two S54 engines, the "clean" one is mine during the last valve adjustment I performed at ~32k. The other has 40k. MY S54 oil change interval is 4500 miles, the other, even though the recommended interval is halved (7500 miles), has broken down oil detergent, varnish and this "gold" tint. You can be the judge, but I'd rather have the engine clean inside.I'd say you're wasting your $$
Yes, they have a good reason...to save them (BMW) a lot of $$$. Prior to them covering maintenance, BMW had shorter change intervals. Yes, synthetic oils are better and I'm guessing the enginerds at BMW did a cost/benefit that said, "hey, we can stretch out the oil change intervals, save a lot of money, and there will only be a .0001 uptick of engine failures if we do this", so bingo, they did it because even with that slight increase of potential engine failures they would have to cover, it still saves them a lot of dinero.All the cars i have driven in the past, i had to change the oil every 6000 miles according to owners manual.....BMW says once a year or 12,000 miles. I find that astonishing. The sceptic in me says BMW recommends this so the car wont last as long and you have to buy a new one sooner. On the other hand i am sure BMW has a good reason for this. Your thoughts?
Yes, the one on the left is mine, I change at no more than 4500 miles (2x / year).Does not pull the contaminants and acid build up out of the engine. And all turbos are hard
on oil because of the higher temperature and pressures. It might neutralize the acid a little though.
Question for the thekurgman
The one on the left is the 3500 mile change motor
Also I thought the valves were self adjusting in the newer BMW motors is this not true?
Do you have any plans to change the timing chain this is also something I never here people do with BMW engines ?
Do you really have a dipstick ?
S54 has a built-in dipstick, see to the left of the intake elbow. It "was" standard for the S engines, yes, but I believe the S65 uses the sensor and has removed the dipstick, which is a damn shame.How did you get the dipstick in?
Is that standard with an M car?
