That is why I am glad the diesels have an actual dipstick , I am not a fan on relying on a sensor to tell me my oil level, have you checked the level on the dipstick ?Got my 1st service done all the way back in May. Seems crazy that the iDrive would just show this now.
I had the same issue but it was immediately after an oil change, since your oil change was 5000 miles ago, I would be concerned with fuel dilution raising the oil level ( diesel in the oil ) When was the last time you checked the oil, was it over the max then ?Had oil changed in January, 5,000 miles ago. I checked the level yesterday with electronic level and it said "Oil too high" Checked with dip stick and it over the word MAX on the dipstick. Took it to the dealer and they are telling me it is a little high but there must be a sensor problem. Can't look at until the 18th with a loner and I am driving to Canada tomorrow. I think I am going to drain some oil out via the dipstick with a siphon and get the level correct on the dipstick and see if the iDrive agrees. I am surprised the iDrive doesn't display a waring message for too high without going into the acutal reading. It sends an error when too low. I wonder if this has been over filled since January. Dire warnings in manual about engine damage from oil too high.
You might want to get this checked out ASAP. The dealers stock these sensors. My car was in and out within like 2 hours.Had oil changed in January, 5,000 miles ago. I checked the level yesterday with electronic level and it said "Oil too high" Checked with dip stick and it over the word MAX on the dipstick. Took it to the dealer and they are telling me it is a little high but there must be a sensor problem. Can't look at until the 18th with a loner and I am driving to Canada tomorrow. I think I am going to drain some oil out via the dipstick with a siphon and get the level correct on the dipstick and see if the iDrive agrees. I am surprised the iDrive doesn't display a waring message for too high without going into the acutal reading. It sends an error when too low. I wonder if this has been over filled since January. Dire warnings in manual about engine damage from oil too high.
Here was my experience with the "Oil Too High": http://www.bimmerfest.com/forums/showthread.php?t=669174&highlight=ddeHad oil changed in January, 5,000 miles ago. I checked the level yesterday with electronic level and it said "Oil too high" Checked with dip stick and it over the word MAX on the dipstick. Took it to the dealer and they are telling me it is a little high but there must be a sensor problem. Can't look at until the 18th with a loner and I am driving to Canada tomorrow. I think I am going to drain some oil out via the dipstick with a siphon and get the level correct on the dipstick and see if the iDrive agrees. I am surprised the iDrive doesn't display a waring message for too high without going into the acutal reading. It sends an error when too low. I wonder if this has been over filled since January. Dire warnings in manual about engine damage from oil too high.
I hope I don't end up going through this!Here was my experience with the "Oil Too High": http://www.bimmerfest.com/forums/showthread.php?t=669174&highlight=dde
