I have a 2011 328i, automatic, 4 door, with 61,000 miles on it (round numbers).
Had the local independent auto repair business (excellent reputation) do a routine oil change. They suspected an oil leak. Cleaned engine, put some dye in the oil, and road tested. Sure enough, the oil pan gasket is leaking, and must be replaced. Estimate is $2700 and might take two days overall. That's a shock. They're not sure about the rear main seal.
How common is the oil pan gasket leak for a BMW of this approximate age, and is it rather involved to replace it?
