People,
Changing oil on my 2009 328i and noticed that with the WIX filter came a new replacement copper ring/washer, I guesss it is for the washer which goes on the plug. Thing is, it is not the same size. It is same thickness but narrower width. It is about 1.5mm and original (yes, its the original washer) is about say, 3mm wide, and looks still good. Would you keep the original wider washer?
