1 - 2 of 2 Posts
I did my first oil change...(very easy after I found the Drain Plug)
My only issue is reseting of the Oil Service Mileage readout (shows up when you first start the car)
I followed the instructions listed below and the END SIA showed up just like it said, but the mileage to next oil change did not change...any ideas :confused:
"You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds."
The King of Common Sense
How to re-set computer after oil change for my 2001 330i.
Turn key off. Hold down the trip reset button (the one on the left) and turn the key to the first position. Keep holding the button for about 7 seconds until Oil service or Inspection along with Reset appears. Release the button and press and hold it again until "reset" starts to flash. Release button Press and release the button. this resets the indicator and it should show the new interval, and display end SIA. Press the button again.
1 - 2 of 2 Posts
