Are there two sensors or just one giving two readings. Conflicting stories with service guy. 2004 645 Cic bought new with 139,000 miles.
1 for oil pressure on the right front cylinder head.Are there two sensors or just one giving two readings. Conflicting stories with service guy. 2004 645 Cic bought new with 139,000 miles.
Yes. The alternator was replaced and the oil temp gauge in my tachometer cluster stopped working. The mechanic ordered part from Germany. Will that work? Thank you.The temp is read off the sensor on the bottom of the oil pan. These sensors don't fail often, but a bad rebuilt alternator will make the sensor look bad. Has an alternator been installed since this started?
