1 - 5 of 5 Posts
Installed a used on board computer. Shows Kilometers and Celsius for the temp. Does anyone know how to reset or is it possible to change to miles and farenheit?:confused:
I have only dealt with the six button type and to change its temp reading, there are some dials on the back that change how it displays the time and temp. Would 'assume' it was the same for the others with more buttons.
Discussion Starter #3 (Edited)
It is the multi-button computer the I put in. I wanted to have an idea of my mpg. Are they interchangable?
obsessed
The bottom right side on the front has a pin hole, stick a paper clip in it and while doing that hit the mpg button until it is what you want. There is 3 options, MPG, M/G, and Liter. Not sure what the diff is between MPG and M/G, I always use MPG. The temp should follow when you get mpg set.
Premium Member
metric FTW
although i just put Euro miles gauges in mine haha. fuel economy is still in metric on the one under the tacho though :thumbup:
1 - 5 of 5 Posts
