Easiest option is to pop the hood and have someone help you prop it up(both sides need pinned at the hinge, drill bit or small screwdriver works fine) and charge the 12V battery so you can pop the trunk electronically.
The manual way involves going up through the license plate light hole, and it is very tricky/frustrating.
