Risky, but it's up to you. Few thoughts I'd have.
First, do you really want a RWD car for your winter car?
Second, tough to see a subframe crack just by crawling under the car -- was it inspected by the dealer under the class action settlement?
Third, auto or manual? Manuals are generally regarded as more reliable.
Fourth, what's the history as far as fluid changes? You'd like to see oil changes every 7500 mi, brake fluid and coolant changed every 2 years, and all other fluids (tranny, diff, etc.) changed by 90,000 miles.
Fifth, plan on replacing the entire cooling system and tires before driving it anywhere. After that, budget $1k-$1,500 a year for odds and ends -- maybe a DISA, a CCV, some Vanos seals, a fuel pump, LCA bushings, etc., etc., etc. You really want to stay on top of maintenance.
Sixth, if it's just a winter beater, I wouldn't worry about the cosmetic stuff (you can get seat covers, etc.), but I would be worried about what that stuff tells you about how the prior owner took care of it. The number of miles is less important than how it was taken care of over the course of those miles.
I'm sure there are other opinions, but these are just some of my thoughts off the top of my head.
Whats up everyone, I dont currently own a bimmer but I have the opportunity to purchase a 2000 328i with 144k for next to dirt cheap. I plan on using it as my winter car so I can rock the tahoe in the summer w out removing the wheels. Anyways, I wanted to lay it down for everyone and hopefully get some responses on wheather or not I should invest in this car.
Whats been replaced:
2 o2 sensors
thermostat
rotors (replaced w drilled and slotted)
calipers
Rubber hose that connects intake manifold with air filter
alternator
battery
headlights
Body condition:
small dime size rust under paint on rear passenger fender
small scratch in paint on front drivers fender
No rust to suspension
subframe not cracked, at least what I can see from inspection
front strut tower not mushroomed
Interior:
two front seats pretty much destroyed
steering wheel cover in shambles
tint peeled off rear passsenger window
Wheels/tires:
Car sat for too long and tires are new but look dry rotted
Wheels are 17" aftermarket chrome but were never removed resulting in bubbling of chrome
I am going to drive it today after work. Asking 3000, going to offer 2500. If he wont take 2500 should I still do this for 3000? What should I listen, feel for while driving the car?
Thank you!
