That looks great Shawn! I'm sure your friend will be pretty pleased with that; especially if you stock it :angel:
Welding is definitely a learned art, no amount of VHS tapes and reading tips will steady your hand. I went through a lot of grinding wheels when I was learning too.
BTW, is that square tubing or barstock? A light "tack" at each joint for initial assembly (and then check for square/plumb & level) before finalizing each weld will go a long way towards keeping the final assembly straight and true. The heat from the welding process distorts the metal, but if it's all tacked together before the really heavy (heat generating) welding is done, the pieces can't pull (very much) out of position. Skipping around (not literally...) will also help to keep the generated heat to a minimum.
But still, NICE WORK! :thumbup:
///M-Bark said:
I finally got off my butt and started doing some projects. First one is a wine rack made for a friend's birthday. The top is a 12" granite tile that matches tiles that he just used for his kitchen countertop. The rack is painted with a hammered bronze finish.
My welds are still ugly beginner welds. So for the most part it's weld... grind... weld... grind... I'm getting great practice with the angle grinder!
The hardest thing on this project was trying to get all the right angles square. I need lots more clamps, corner clamps, magnets, and jigs to make this easier.
Anyway, I thought it turned out acceptable (more like PRETTY DAMN GOOD) for the first project.
