Outer CV Boot Help!
5.7K views 63 replies 7 participants last post by  Addictive ShoppeRx
#1 ·
2011 X5 35i with a damaged outer CV Boot. Didn’t realize I had a problem until a recent trip to the dealership for a recall. Was quoted $1200 to replace the passenger CV Boot.
After inspection, there is grease everywhere, but the boot looks good (I’m sure there is a crack somewhere). Ended up buying the OEM boot that comes with the grease and thought I would take to my Indy. Quoted $400 and actually debating as I don’t want to do myself because it’s too hot and can’t find any simple documentation on an E70.
I know I should just tackle myself as I have the parts and tools (have 36mm 12 point socket). Anyone have a video or guide? My CV isn’t making any sounds and no issue, just making a mess and will soon dry out.
#32 ·
Just a smearing of diff lube on the end of the splines is all that is necessary. You just want that circlip to snap in cleanly.
It is my understanding that the OE for BMW's shafts does not sell aftermarket. Unless you purchase Genuine BMW, you will see differences. I would triple-check the part numbers and eyeball the distances to the bends to verify.
#39 ·
I’m awaiting GKN corporate and ECS tuning to investigate. They are both concerned I received the right part # on the wrong CV Axle.
I pray I didn’t damage my front diff if it’s the wrong part. FML! I cross reference before installing with FCP and ECS before.
Now I got to take it all out again and wait for a different one.
#44 ·
Got my CV Axle rebuilt! Only $85 and looks and feels new. And yes, GKN is the OEM. Too bad the replacement GKN CV Axle I ordered is too short :(
Question, I lost about 2-3oz of diff fluid when removing the CV Axle. Do I need to worry about refiling? If so, I can't get the BMW brand fluid at the dealership. Doesn't the front diff just take synthetic 75W-90 gear oil? Any brand you recommend from Autozone?
I had the guys empty and fill my front diff a few months ago with the BMW brand gear oil when they did my oil pan (just none left).
Here is my original CV Axle rebuilt. I kind of ruined the fresh paint some by not letting it dry.
#50 · (Edited)
It's a good idea to replace output shaft seals. There is an o-ring inside the passenger shaft adapter bolted to the oilpan, as well. Four bolts will pull this adapter off.
As to the seals - You will carefully pry out the old seal with a prybar or jumbo screwdriver. Take note of the direction and depth of the old seal before you remove it. Then, clean the seat and gently square-up the new seal into the bore using your hands. Using the old seal as a driving tool, line its edge up with the new seal and tap, tap, tap it home with a hammer- slow & steady...
If you jank it up in any way such as bending it or damaging the rubber seal, pull it out and buy another.
Coat the o-ring & lips of the seals with lube or silicone paste before pushing the shafts through. If you damage them, you get to do the job again - which sucks.
#53 ·
This job sucks! I’m doing a number to the old seal. It’s almost like the shop that did this before used glue (which I doubt). I think I’m going to need to remove the four bolts to the shaft adapter. Those seals were just changed also.
Whoa hold on.
Use a seal puller not some janky screw driver.
It also doesn’t matter what you do to the old seals as long as you don’t mar the bores in which they sit. A light smear of RTV made for GEAR OIL on the inside will both add lubricity and sealing.
Use a socket of the same OD as a drift to drive the seals into place. I usually use two sockets: one of the seal’s OD sitting as a cup, and another smaller socket sitting inside the larger as a driver for the hammer. You DID measure how deep they sit from the face of the diff, right??? [emoji6] It doesn’t matter if you didn’t, they sit hard on a shoulder inside the bore. Drive them in until they sit flush, but don’t over-drive or you’ll deform the seal and have leak issues. Listen to the change in sound as you’re tapping, the rise in octave is pretty apparent.
Via the interwebs
#56 ·
You need to jiggle the axle as you’re stabbing it in; the slightest angle binds it. I clean the hub bores with a pipe cleaner before inserting the axles, and also quickly bevel their splined ends slightly with a file before inserting.
If you think those seals are bad (they should take less than 3 minutes to extract and install), just wait until you have to do the front crank seal. If you’re close, I’m willing to lend or rent the tool.
Via the interwebs
#63 ·
Via the interwebs
Yeah the front crank seal.... Kicked my ass trying to get it out... Finally got mad and cranked the tool till I had nothing left in me. And that's what got it out lol!!🤣🤣
#57 ·
Thank you @dukedkt442 for the feedback. I will try again tomorrow. I think it’s binding. Shouldn’t be this hard. Is their a tool to make this job easier?
as far as front crank seal. Do you mean the front crankshaft seal? If so, I would do 5 of those jobs vs.changing a CV axle and outer seal. The front seal to me was so much easier. Accept I had to get the removal tool modified.
#58 ·
I was, simply because of the need for the extraction and pressing tool. The diff seals are the same process of my 50s and 60s tractors, so I’ve done a few of those.
If you have a hard flange, you can try using a round stock drift to tap around the axle from the engine side to drive it into place enough to get some threads emerged. Once that occurs, use the old axle nut to pull the axle through the hub.
Via the interwebs
