1 - 3 of 3 Posts
hi all i have a problem and wondered if you could help i have a 323 coupe 1996 and its just started overheating and its blowing cold air have no oil leaks coolent leaks and it runs and drives perfect did 45 mile in it and was fine then got home went to shop and it started
Yes, they're real!!!
...it runs and drives perfect...
Well it ain't a perfect driver if it overheats, right!? ;) If you're not getting any heat from the heater, then I say you are low on coolant. :dunno: Better get your cooling system checked by a certified Bimmer Tech anyways. Could be nothing could be something. Hope you get it sorted out, g'luck!
1 - 3 of 3 Posts
