Hi, hoping someone can shed some light.
Around a year ago my beloved 00' E46 316i se ran into a few overheating issues.
Its a 1.9l Inline 4 from factory and from what I can gather these engines were created for the 318i e36's.
The car was bought on 54k and was absolutely mint, around 6 months later we sit on 79k after being put through its paces regularly.
Nothing has ever gone wrong on the vehicle with an immaculate MOT history. The only problem's I've had being brake pads and tyres... lol
Around 6 months in the car very slowly started getting through coolant to where around 3 months later it was needing to be filled at least 1/2 every 4-5 days.
The car eventually overheated on a short journey and a pin-prick sized hole where the radiator joins the expansion tank was shooting steam out.
Being barely drive-able, the radiator was replaced.
The garage it was staying at suggested it may be the thermostat or water pump.
He found the thermostat wouldn't appear to open in boiling water, so I bought a new thermostat.
With this not having much effect, I replaced the water pump.
The problem seem to be fixed for around 1-2 weeks, excellent I thought. Problem Solved.
How wrong was I...?
Two weeks of regular use later I took the car for a short drive and parked up outside of a friends garage with the engine idling, after around 10 mins of sitting there, bang, the expansion tank blew the back out of itself and dumped its coolant everywhere.
Having come from ECP, I replaced this with an OEM expansion tank.
It has sat looking very confused ever since.
Now, the car produces a small amount of white smoke when cold, which it never used to, which point towards a HG failure.
On two occasions I have also found milky residue in the expansion tank. NEVER in the block or on the dipstick, which I find very odd.
The car last had an oil change when it visited its main dealership early into my ownership and the oil is still very very clear.
Clearly the car is building too much pressure, the leak into the expansion tank is of course worrying, but possibly not damming??
Some have suggested it being the oil cooler, or possibly the heater matrix. Is this possible?
Personally, I pride myself on being a capable/competent driver, but mechanically I have zero knowledge.
Any advice would be greatly appreciated.
Thank you in advance.
How wrong was I...?
