Well I have installed my new P39 projectors with AEs from UMNITZA and I am very happy with fit and finnish, and they look great especialy comparred to the clouded oem lights. The only problem I had was I went against my own advice and wired the AEs directly to the park lights and with the lights turned on they worked fine and I think the AEs light well and are very visable evan in bright sunlight and I get a lot of compliments on them. But the only problem with wireing them directly to the parking lights is with all lights off and ignition switch on or the engine running the AEs will strobe, right,left,right,left, after a little research I found that the light control module sends a low voltage pulse to all lights controled by the module to ck the bulbs even when the lights arn't turned on, the voltage is so low that it wont light a regular bulb but the AE light strips will so I just installed standard Bosch relay in the system and that solved the problem
