Hey Dan,
I lost the printout of the message you posted at .org on the parts and procedure that you used for the brake conversion of your car. I did a search at .org and could not find it.
So, can you direct me again to the specific post?
I was going to just change the brake pads for my 323i with stock ones (actually I already had the parts from Cutter). However, the dealership's service advisor said that the front rotors were a little bit warped, and suggested I go with aftermarket rotors.
Btw, how is your brakes now? I remember you said the mushiness was taken care after you stomped on them a couple of times, right?
Dave
