1 - 18 of 18 Posts
The Original Dr. Phil
Clem
The flood gates are now officially open:yikes: First mod installed today.................ECIS CAI. Any ideas what to do next?
Thanks to Alex325i for the special package from Florida:D Took me a whole 10 minutes to install it and 20 minutes of testing it out before I made it back home:bigpimp:
First impression.............definately a better acceleration response:D A$$ dyno felt a slight increase mostly in faster RPM climb, but this could be my imagination:dunno:
The vacuum sound really kicks in around 3500rpm. At light throttle there is a slight squeling type sound, is this normal? Then there is just the normal engine sound up to the mentioned 3500 mark.
Here's a few before and after shots.................
this one is a little dark but you get the idea
and the infamous Nate pose:tsk:
Discussion Starter · #5 ·
DougDogs said:
Looks good Phil, but, time for some simple green under the hood. Or do you pick up too much dirt on those Amish farms:dunno: :dunno:
That dirt was under the OEM box, not to worry I cleaned it up right after I took the close up pic:)
But you are right the farms are really tough with the dust:(
Discussion Starter · #6 ·
Re: Re: Paging the Corruptor
nate328Ci said:
Yes, normal.
Thanks Nate:thumbup:
The ACS brace................hmmmmmm as soon as Clem gets back to me I guess:dunno: :p
Discussion Starter · #7 ·
After a couple days of use I have update #2 - mpg on current tank down ~ 3:(
Fun level on current tank up ~ 47%:bigpimp: Ok Clem send on the next batch of goodies:yikes:
Everything sounds good Phil.
ECIS is operating in normal parameters. Glad you're happy with it.
Do you want the brace? You never confirmed or rejected. Let me know ASAP I have a couple of interested parties.
Discussion Starter · #10 ·
Ack said:
Phil -
Looks good! :thumbup: Are you out of your warranty period, and if not, does the ECIS affect the warranty at all?
I think they will give you the "voids warranty" speech :dunno: But I plan on swapping out OEM and ECIS when I go in for new pedal and any warranty/maintenance work:)
Discussion Starter · #11 ·
Since you said it is mostly cosmetic, I think it would be wise for me to wait until UCC or someone else;) comes out with sways for the xi's:dunno:
Want do you think? Or of course for the right bargain price I might be tempted;) :bigpimp:
Working on a deal for it right now but if it falls through I'll let you know.
IMHO wait for sways, strutbars are SLIGHTLY affective but more eyecandy.
Discussion Starter · #13 ·
Thanks for the straight advice Clem:thumbup:
Discussion Starter · #15 ·
Clem said:
Would I steer you wrong? :angel: :angel:
Uh :dunno:
j/k
I see there is quite a bit more activity over on the dark side:eek: I may be getting drawn in deeper than I thought:yikes:
Discussion Starter · #17 ·
Clem said:
Follow me into the path of darkness.......................................... :)
I may have to reload AIM at home so I can follow you directly:D
I went out for lunch today after I atre my bagged lunch, just wanted to continue listening to the "hiss" of the CAI and throw it through a couple of curves:bigpimp:
I'm hooked:eeps:
I'm hooked:eeps:
Thata boy!!!! :thumbup:
AIM is the Devil's Advocate. Load 'er on up :D
1 - 18 of 18 Posts
