Paint problem
1261 Views 6 Replies 3 Participants Last post by  The HACK
I had a small bird dropping on my roof the other day, nothing serious and no damage was done since I got rid of it quickly.
I used clean cold tap water which I carelessly left on the car - in the sun. This left some serious water spots that I just can get rid of. Its like the edges of the water spots are etched into the clear coat.
What do I do? :cry:
JSE
1 - 7 of 7 Posts
50/50 mix of vinegar and water. Rub the affected spots gently with a cotton towel dipped in the solution. Let it sit for a little, and then rinse. Repeat as necessary.
See less See more
Already tried that - but no effect at all.
JSE
Re: Already tried that - but no effect at all.
Next step would be to try using clay. Keep the area well lubricated with car wash solution, and glide the clay back and forth over the affected areas.
How exactly does this clay work?
I tried an of the shelf paint cleaner, which I normally use to remove light scratches (like swirls). This also had not effect at all.
I am worried that the edges of the spots have actually etched the paint.
JSE
See less See more
Re: How exactly does this clay work?
If it didn't sit that long, I think all the paint needs is a good quality cleansing. You may find that it will clear up a bit by itself as well.
JSE! don't mean to hijack your thread but...
Do you have the instructions on how you installed the clown nose blinky thingy somewhere online I can access? I installed the E46 M3 interior rear view mirror and now I can't get the autodimming mirror to work. From what I gathered I need to buy a new wiring harness and take the roof liner off so I can hook up the wiring harness to the Central Control Unit (most likely just to the fuse box, but I'll have to check that).
I remember you had to jump through quite a hoop just to hook up your alarm?
See less See more
1 - 7 of 7 Posts
