1 - 4 of 4 Posts
Zinnobitch
Hello,
The front brake pad sensor plug was very brittle and broke during replacement. I checked in realoem and can't find the part number for the plastic white two wire housing. I am looking for the side connected to the car, not the brake pad sensor side. All help is appreciated.
housing
(this si for E53 ) but may fit...
https://www.ecstuning.com/b-genuine-bmw-parts/plug-terminal/61131393742/
I think this is universal
https://www.ecstuning.com/b-genuine...dxk_WO7vz74WAmf6znaAhxnggsdlyroxoCK9gQAvD_BwE
You can remove old wires if you lucky and put them back into new one - but sometimes they got damaged in process so I would oderd couple wires in case .... so you can install them in new housing and cut the old wires/splice..
https://www.ecstuning.com/b-genuine...dA5omxsDJxWhVr4HuVoraKpI94MOUXgxoCYJ8QAvD_BwE
Zinnobitch
Discussion Starter #4
Previat,
I don't think you'll find it separately. It is part of the main harness #61119166395. You might have to do a repair (clean and seal the two connecting parts with shrink tube ) or cut the connector off a junked car.
That's unfortunate, thanks for the response! Looking for a used one sounds like my best bet then.
1 - 4 of 4 Posts
