1 - 8 of 8 Posts
Yes, I know this was posted within another thread, but I felt it would do a better job on it's own. Sorry for those whom have already seen this.
I am parting out my 1992 Black 535i Manual - Grand Rapids, Mi
Interior: (Parchment)
Front door skins - 40
Steering wheel airbag - 45
Fog light switch - 5
Glove box (w/ working latch!) - 25
Sunroof motor - 20
Door: (all from passenger rear)
Window motor - 35
Actuators - 15
Door handle w/ trim - 5
Glass - 10
Lights:
Low beams (w/ bulbs) - 25
High beams (w/ bulbs) - 25
Turn signals (w/ bulbs) - 10
Front end:
Grille (w/ inserts) - 30
Headlight surrounds - 10
Front bumper support - 50
Radiator Support - 10
Washer Fluid Reserve - 15
Air box w/ new filter - 30
Radiators: both w/ fan shroud - 75
Drivers side front fender (black) - 25
Side mirrors - 25
Steering & Suspension:
Front brake assembly: Rotors, Pads, (both <1k miles w/ new sensor), & Calipers - 50
Racing Dynamic Front Sway Bar: 27mm - 100
Lower control arms (<5k miles) - 25
Upper control arms (<5k miles) - 50
Center tie rod (<5k miles) - 50
Tie rod ends (<5k miles) - 25
Pitman arm (<5k miles) - 10
Engine Compartment and other things:
Drive shaft (new center support & bearing) - 150
5-speed Getrag Manual Trans (w/ linkage) - 300
ABS pump - 30
AC compressor - 40
HVAC blower motor - 20
Coolant reservoir - 10
Rear End:
Trunk lid (w/ bulbs) - 50
Taillights (w/ bulbs) - 40
Fuel pump (new filter) - 50
Bumper trim - 20
Spare tire - 30
Modules:
ECU - 45
ABS control module - 30
Relay Module (RM) ending in 741 - 10
Light Control Module & Relay (LKM***8211;L) - 15
Cruise Control Module - 10
Check Control Module (CCM) - 5
Stereo Amplifier - 40
Security System Control Module - 20
I have tried to make this list as accurate as possible, but if you don't see it on here, just ask and I can tell you if I have it or not.
As things are bought I will delete them from the list.
Nothin like an E34
I bought one "like new/reman" it had a 2" hole, wrinkled, and had rust. Mine is rusted in half, and has many holes in it.
Will the cluster and headlight switch fit a '92 525i? If so, I'll take them. PM me?
Sent from my SPH-L720 using BimmerApp mobile app
Drive her like an ///M
OEM front floor mats? Could I see a picture?
Sent from my SGH-T839 using BimmerApp mobile app
1 - 8 of 8 Posts
