For those that have done this or planning to do this, maybe you can help me out with buying and replacing what parts. I have a 2001 530i auto with 86k miles now. Please let me know what else should I replace or missing on list...and if you have the part # it would be great. So far this is what I have on my list from Beisan's site:
Beisan's vanos Seals
Vanos gasket (11-36-1-433-817)
Gasket sealer (Permatex High-Temp RTV) - recommended by MatWiz
2 x vanos oil hose/pipe washer (32-41-1-093-596)
valve cover gasket set (<09/02 11-12-9-070-990)
15 x valve cover bolt grommet (11-12-1-437-395)
oil fill neck gasket (11-12-7-526-447)
2 x vanos piston bolt (11-36-1-748-745)
4 x engine cover bolt/nut cap (11-12-1-726-089)
fan shroud rivet (17-11-1-712-963)
Adding the winterized CCV stuff as Fudman recommended.
CCV & Hoses/pipes:
Cold climate pressure regulating valve 11-61-7-533-400
Cold climate vent pipe 11-61-7-533-398
Cold climate connecting line 11-61-7-533-399
Cold climate vent hose 11-15-7-532-629
Return pipe 11-61-7-504-536
dipstick o-ring 11-43-1-740-045
*I am not planning to get the dipstick guide tube because its not really thhhhat cold here in NYC and its not a cheap part to just replace for the heck of it.
CCV & Hoses/pipes:
