Passenger door on my x5 2003 won't open from outside
Yes, this happened to mine for BOTH doors. It's the door handle actuator. Unless you're up for removing the interior door panel, cutting away the protective plastic and moving the window mechanism aside, brace yourself for a $300 hit. You may be able to come out cheaper if you order the door handle actuator yourself and just pay to have it installed.Passenger door on my x5 2003 won't open from outside
It is not as hard job as it may sound..after you do it onceYes, this happened to mine for BOTH doors. It's the door handle actuator. Unless you're up for removing the interior door panel, cutting away the protective plastic and moving the window mechanism aside, brace yourself for a $300 hit. You may be able to come out cheaper if you order the door handle actuator yourself and just pay to have it installed.
If you are doing it yourself, stay away from the cheap aftermarket parts. You'll spend more time trying to get everything align, and it'll just break in a couple of months.If you let mechanic do it - it will be close as part itself is $100 - 140 depending where you buy if from plus about 1.5 hours of labor...
If you doing it - you can buy aftermarket part for less than $50 ...
I agree but some like cheap alternative....and like saving $50 and do job 2xIf you are doing it yourself, stay away from the cheap aftermarket parts. You'll spend more time trying to get everything align, and it'll just break in a couple of months.
Genuine BMW carrier will just go in without a lot of fuss and they have a 2 years unlimited warranty.
that happened to me and my door handle carrier was broken, very common issue.I replaced mine and been good ever since ,about 4mths ago.Passenger door on my x5 2003 won't open from outside
