1 - 20 of 29 Posts
Instructor of the Stig™
The factory rubber bushing design allows for deflection in the caliper, but no real service requirements. Caliper deflection can cause uneven pad wear and less than amazing pedal feel.
Our design removes the caliper deflection which enhances pedal feel, it also causes the caliper to slide in and out evenly which prolongs pad life by providing equal pressure across the entire pad. Unlike other solid bushings our design is a sealed system, this is going to stretch your service interval far beyond the typical solid open end brass bushing design and allow the service interval to be comparable to most street pads life. Servicing is simple remove, clean, grease, reinstall, a very simple process when changing brake pads.
-James
They may be okay, but they do need periodic cleaning and relubing.
A solution looking for a problem.
(oOO\(|||) (|||)/OOo)
Let's take these one at a time.
Are these any better than stock?
I should hope so; but quantify "better." According to ECS, they "reduce deflection," which is always a good thing. Reduced deflection (movement of the braking components) should improve initial bite and "pedal feel" (firmer, more distinct engagement point). But at what cost? It seems like a potential squeak spot to me, especially in the braking system.
Anyone has any experience with similar or same product? Comments?
I installed the standard guide bushings about 10k miles ago, and I have no complaints. Of course, I'm not tracking or autocrossing my car, so I'm not super sensitive to changes in my brakes. I also went with cheaper Meyle rotors and Akebono Euro ceramic pads (ZERO DUST!!!!!), which did reduce the initial brake bite somewhat.
Waste of $$ or money well spent?
It really depends on what you want from your braking system. I think you might be wiser to save up for a system like the ECS big brake kit for our e39s, as it will have been designed for high performance out of the box. Our e39s, like it or not, are primarily designed for comfort and daily drivability. However, if you want a firmer pedal and more consistent brake wear, with some extra stability and aren't afraid to do it yourself, this seems like a reasonably priced upgrade for the standard braking system. I, however, will be saving up for the big brake kit.
computiNATEor - well put
Discussion Starter #6
This is what I was looking for.
Big turn-off having to service these things on a regular basis.
My calipers are serviced "regularly", but this is just rebuilding them when I change the rotors & pads and the brake fluid flush every 2 years. I don't want to do more if not necessary, which this set seem to need.
Thx Ed & Computinateor
+1, the idea looks great and at a couple points over the years (when I was due for pad changes) I was going to order these (or one of the competing, but similar products) and did not, due to a few negative posts from folks that used them. I forget off hand what the issues where, but I think it did have to do with actually more frequent service or they had issues. One guy posted he even went back to the stock guide pins/bushings. I asked a couple BMW techs about it...they shrugged their shoulders, basically had no opinion...saying there were some advantages, but also some negatives...again, don't recall the specifics. Sorry if this post is not more helpful....my opinion is to leave this stock...
I love ECS Tuning products...get their Exact Fit braided brake lines instead! ;)
Under the lift arms
I must be talking to a wall... ive been bitching at you people for years about this... and now?
lol
what do you think?
I have 8 sets of those.. and they fit on every bmw between 82 to current
only 2 cent i have to add is dont lube them... the lube will pick up detrius and shorten there life..
They are machined they dont need lube, they are also soft... do not hammer with anything on them.. when you do it right they will push in by hand.. the external C clip is what keeps em on the car,
i also made a set my self with a material called Amco.. almost the same stuff as what people who sell em are made with, just a little more hardness
I think these ones last longer... but your gonna have to find that out for your self...
Seek to understand,^Value
I have thought about getting those brass caliper pins...
To help against any slushy pedal feel.
When I hear adverbs being applied to brake feel, I have trouble identifying with those feelings.
But, while my hearing may be bad, I can see caliper pins, and uneven pad wear on my own vehicle.
- One user's example of a complete brake job with all torque figures, specs, measurements, fluids, decisions, tools, tricks, mistakes, suppliers, costs, etc., that it entails (1)
I just removed the wheels from my fronts, which desperately need new pads.
So, since I'm just about to start a front brake job ... how would I know whether my stock original bushings are in good shape or not?
Discussion Starter #13
Here are my last-replaced rears, for example, which show uneven wear:
Blue, that's why I replace the rubber bushings every time I change the brake discs & pads (together with a complete caliper rebuild). Also, every 2 years when I flush the brake fluid, I take the pins out & clean them. In time, I noticed the rubber degrades and starts leaving deposits on the slide pins. I thought this product being metallic, I won't have that issue, but as it turns out, there is more maintenance involved than I am willing to do. And I also observe the TIS which states NOT to use lube on the slide pins. My car never exhibited that uneven wear, but I can attest that by the time I need to do the brake fluid flush, that the calipers don't move as freely - that's the reason I take out the pins & clean them (rubber deposit). For my car, the p/n is 34111157038 if you go with ATE (about 13$/set) or p/n 34216869617 if you go with OE BMW (which is essentially the same), but costs about 31$/set. My slide pins are still original, shiny and work well.
Another culprit for uneven wear could be a busted piston. This is the reason I rebuild the calipers every now and then - they are main safety component. If the piston starts to rust ever so slightly, or due to that getting pitted, the best bet is to trash it and buy a brand new brake caliper. Centric is manufacturing some decent calipers that don't break the bank.
0.02
0.02
Do you mean Centric is producing brand new calipers, or remanufacturing? If new, where are they available? I've haven't ever noticed listings for new, Centric calipers.
I do agree that it's a good idea to very carefully check piston condition before retracting them back into the caliper bore when installing new pads. Which of course means folding back the dust boot, which is a good opportunity to check for splits & cracks.
Another option is a DIY rebuild - new piston & seal kit. Rock Auto sells E39 pistons from Centric.
A few years ago I saw an article describing why a re-manufactured caliper may not be a good idea. Many premium caliper OEMs apply a coating to the caliper cylinder, usually zinc plating, which provides some "slipperiness" for piston movement. Reman vendors usually clean returned cores with shot or glass bead. That treatment removes the zinc layer leaving the base metal (iron or aluminum) exposed. The slight stickiness & hangups as the piston moves back and forth would promote cocking in the bore and accelerate wear & reduced life for the remanufactured caliper. BTW, not a safety issue - the caliper will still work, just not as long as an original.
It made sense to me so I've since either bought new or done my own rebuild.
Discussion Starter #15
RDL, so far I did rebuild all my calipers - the pistons were in great shape. If for a reason I will ever find a pitted or scratched piston, I will replace that caliper. A new OE (ATE) caliper is anywhere from 275$/side to 330$/side. Remanufactured are around 130$ or so. These are for the fronts.
Below is the Centric table with the equivalent:
2003 BMW 530i
8 Record(s) found <TABLE id=AppDataGrid style="WIDTH: 87%; BORDER-COLLAPSE: collapse" cellSpacing=0 rules=all border=1>*******><TR class=header><TD>Part Description</TD><TD>Flavor</TD><TD>Notes</TD><TD>Notes</TD><TD>Position</TD><TD>Part No.</TD><TD>Fn</TD><TD>Per Car Qty</TD><TD>Pic</TD></TR><TR vAlign=top><TD>Caliper Kits</TD><TD>Brake Caliper Repair Kit</TD><TD>E39</TD><TD> </TD><TD>Front</TD><TD>143.42008
</TD><TD> </TD><TD align=center>2</TD><TD>
</TD></TR><TR class=alternate vAlign=top><TD>Caliper Kits</TD><TD>Brake Caliper Repair Kit</TD><TD>E39</TD><TD> </TD><TD>Rear</TD><TD>143.34018
</TD></TR><TR vAlign=top><TD>Caliper Piston</TD><TD>Steel & Aluminum Caliper Pistons</TD><TD> </TD><TD> </TD><TD>Front</TD><TD>146.60009
</TD><TD>60mm Piston</TD><TD align=center>1</TD><TD>
</TD></TR><TR class=alternate vAlign=top><TD>Caliper Piston</TD><TD>Steel & Aluminum Caliper Pistons</TD><TD> </TD><TD> </TD><TD>Rear</TD><TD>146.40023
</TD><TD>40mm Piston</TD><TD align=center>2</TD><TD>
</TD></TR><TR vAlign=top><TD>Calipers</TD><TD>Posi-Quiet Loaded Caliper</TD><TD>E39</TD><TD> </TD><TD>Front Left</TD><TD>142.34098
</TD><TD> </TD><TD align=center>1</TD><TD>
</TD></TR><TR class=alternate vAlign=top><TD>Calipers</TD><TD>Posi-Quiet Loaded Caliper</TD><TD>E39</TD><TD> </TD><TD>Front Right</TD><TD>142.34097
</TD></TR><TR vAlign=top><TD>Calipers</TD><TD>Posi-Quiet Loaded Caliper</TD><TD>E39</TD><TD> </TD><TD>Rear Left</TD><TD>142.34546
</TD></TR><TR class=alternate vAlign=top><TD>Calipers</TD><TD>Posi-Quiet Loaded Caliper</TD><TD>E39</TD><TD> </TD><TD>Rear Right</TD><TD>142.34545
</TD></TR><TR><TD> </TD><TD> </TD><TD> </TD><TD> </TD><TD> </TD><TD> </TD><TD> </TD><TD> </TD><TD> </TD></TR><TR align=right><TD colSpan=9>1</TD></TR>********></TABLE>​
If buying a centric remanufactured caliper, they cost around 75$ - 80$/side. Centric claims they replace the piston with new ones (here is the link - you have to scroll down a bit to see the piston description), but basically this is what they claim:
<TABLE cellSpacing=2 cellPadding=1 width=500 border=0>*******><TR><TD width=110><INPUT height=200 src="http://www.centricparts.com/images/stories/pistons.jpg" type=image width=200 longdesc="undefined"></TD><TD width=425>All new pistons
Every Posi Quiet brake caliper piston phenolic or steel is replaced to guarantee proper performance throughout the lifetime of the caliper.
well actually the piston doesn't contact the walls of the caliper bore but rides on a square cut o ring , all the coating does is protect the inside of the caliper from corrosion for those that don't flush there system as most people don't, but a coating on the piston will protect it from wear that could lead to uneven movement of the piston
I don't agree with "doesn't contact the walls of the caliper." The seal doesn't have the rigidity or span to hold the piston axis true to the cylinder axis.
In operation, any piston cocking will depend on the angles between the caliper ears opposite the piston wrt to the cylinder axis, the ears' contact on the outer pad, any taper in the pads, contact between the piston and the inner pad and the caliper locating pins/bushings alignment with the cylinder. All of these should be true, but aren't necessarily, due to manufacturing tolerances and wear or seizing. The piston clearance is only ~0.2 mm or so & thus even a very small misalignment angle will cockthe piston into contact. For instance, consider a pad frozen/jammed in the caliper carrier bracket, which twists the pad wrt to the caliper - the forces are no longer aligned on the same axis ... and the part with the most compliance to adjust for the mis-alignment is the piston/seal. So the piston gets cocked wrt to the caliper bore & the bottom of the piston (furthest from the seal) is forced into contact with the cylinder bore.
Another illustration. It's fairly common that a piston will jam itself in the bore when one is removing (and later inserting) a piston during a re-build. Which demonstrates that the seal alone is unable to keep the piston axis true to the caliper bore axis.
I'm confused.
With the calipers still on the car, and the pins removed, is there any way to easily INSPECT the OEM rubber bushings by eye (to see if they are damaged)?
> E39 (1997 - 2003) > To Lube or not to Lube Brake Guide Pin
Or, must they only be inspected upon caliper removal from the car (which doesn't normally happen in a typical brake job) and with the caliper disassembled?
In addition, I can easily find plenty of in-vitro pictures of replacement OEM (rubber) or redesigned (brass) caliper pin guide bushings, from almost every manufacturer.
But, does anyone have an in-situ picture of their stock rubber oem bushing still inside their partly disassembled oem caliper (like this picture, only for the OEM bushings)?
Doru
Thanks for the data. The ATE calipers sure are expensive. Last year I thought I was going to have to replace fronts due to rusty pistons. I found listings for new ATEs at ~US$150. But that was a real find - one wonders if it wasn't a pricing error.
In the end I found Centric pistons (from Rock Auto) & bought ATE seal kits. The pistons were steel & appeared well made. I've put 20k km & a winter on them with no problems apparent.
EDIT: PS I also found listings for pistons on a UK site. If Rock Auto discontinues the Centric pistons try a Google search. Or post back, I may have saved the link ... somewhere. :(
Discussion Starter #20
RDL, thanks. I know one day I will have to replace the calipers (or the pistons at least - which would be more cost-effective). I'm not sure what the size of those pistons is (length / diameter), I know I can throw a caliper and measure them, but once they're out, I need to replace on the spot, it's my DD and I can't wait days/weeks for one part to show up. usually I have some sort of "stock" for what I know I need to replace 100%, or what can fail (and is not very expensive).
Bluebee, the rubber bushings degrade over time and should be changed. Also, they wear as in losing material (inside) over time. They're not very expensive, use the ATE service kit which is about 12-13 bux/side every 4 years or so. The TIS state not to lube the slide pins, because the rubber bushings (new) are coated with a white-ish substance that allow the slide pins to glide. That coating degrades and vanishes over time as well. Doesn't feel like grease.
1 - 20 of 29 Posts
