1 - 7 of 7 Posts
I looked in the manual and couldn't find how to program the phone number with a extension number into the phone book. Any help would be appreciated. TIA
cheers
vern
I have a 2008 535 and the car automatically uploads the phone numbers and extentions programmed into my cell phone when connected by bluetooth.
I could not find this either. But my 2010 535 w/ Nav now has a feature where you can key in extensions when you need them. Works great. Yours may have it as well.
Discussion Starter #4
Wher can you find it?
cheers
vern
Discussion Starter #5
Thanks for the information. I checked with Sprint and I can't add the ext. on to the number
I have to wait until I get connected and then punch in the ext.
cheers
vern
P for pause to insert extension
You will have to insert "P" pause on your cell phone and type the extension that prompts the phone to let the number ring then dial extension. That is the same way I use for my voicemail P then type in your password so you don't have to type in your password everytime you call voicemail.
Discussion Starter #7
My problem is when I use the blue tooth, because I can't put the ext on to the phone # I have to wait until the connection is made then punch the ext # in on the cell phone.
cheers
vern
1 - 7 of 7 Posts
