There is good information today from cn90 and QSilver7 about fitting an elbow into an aftermarket battery, over here ...
> E39 (1997 - 2003) > DIY: Autozone H8-DL Battery
See also:
- How to test a BMW battery & alternator (1) & the most often recommended diagnostic procedure to test for overnight parasitic battery drain (1) & one user's attempt to locate, describe, and photograph all fuses and relays in the BMW E39 with a picture of every fuse & relay (1) & how to choose a good aftermarket battery (1) and a simple battery replacement DIY (1) & Cn90's explanation of where to get alternator rebuild parts (1) & how to troubleshoot a bad FSU final stage unit (1) and how to build a test jig for your FSR final stage resistor (1) & how to repair solder cracks in your blower motor resistor (1) & how to replace your HVAC blower motor control (1) (E46) & what FSU is the right one to buy based on user experiences (1)
Just purchased an autozone H8-DL battery to replace my autozone 49-DL that was on its last legs. Battery fit perfectly and is in fact a few mm taller than the 49-DL. I did not need to use the shim that I had with the old battery. My biggest issue is that the vent hole is smaller than what was on the 49-DL and so I couldn't use the old fittings. I asked at autozone if it comes with a vent kit or even if I could buy one and the clerk had no idea of what I was talking about. I went to Home Depot to try to buy an elbow like that mentioned in this thread but they did not carry such a piece. So for now I don't have the vent tube connected. I left the battery uncovered so any hydrogen will hopefully vent into what is the large area of the trunk and tomorrow I will see if I can get an elbow that fits either at the local bmw dealer or another auto parts store. Anyone using this battery should make sure they have a proper fitting elbow first!
See also:
