OK, here's an update. l1tec, you were right, none of the dealers stocked this line, so I just bough some "european" bulk brake line from the auto parts store and a line bender and I copied the old one as best I could and installed it.
Worked like a charm and was much easier than expected. The hardest part was removing all the underbelly pans and plastic pieces coving the lines. Anyway, line is in, no leaks, everything is good. So, once the line is in I bleed all the brakes, and took it for a test drive. Well, the brake is still mushy. It works OK, but there is obviously air still in there somewhere.
Now since the brake line was off, and the master cylinder res was emptied when the line broke, I'm sure there was a lot of air in the system. In my Bentley Manual it says that you need to hook it up to a BMW computer and put it into bleed mode as "bleeding the brakes if there was significant air in the system will be very difficult to remove by traditional methods." Is this true? Will I be unable to bleed the brakes traditionally (with a MityVac or the old fashioned 'wife pumping the brakes for me' methods)?
Do I need to take it in to a dealer or Indy with a DISPlus, MoDiC or a GT1 computer to put it into "bleed mode"?
