1 - 13 of 13 Posts
I'm sure there are tons of these threads but I haven't been able to find them with search, if someone can point me in the right direction that'd be great.
I want to fix the plastic ring around the speaker in my passenger door panel, Anybody know where I can get a new housing with an intact ring?
Look up the part number on realoem.com and google search on it. You should find lots of sources both new and used.
Discussion Starter · #6 ·
I've found a few on ebay but they look a little different than the Harmon Kardon speaker housings, I don't think they'd work?
'17 X1 - Rooster Cruisin'
I thought that you were looking for just the tweeter surround? Look closer at it; it looks the same. At less than half the cost of new - if you can even find them.
Discussion Starter · #8 ·
I just bought a pair of speaker housings for the harman kardon on ebay! $55. Hopefully these ones stay intact... I'm doubtful.
Yay! :thumbup: Post back when you get them and let others know how it worked out. Some of these parts are getting hard to find or afford.:eek:
Discussion Starter · #10 ·
Will do. It'll likely be a while as I also just ordered the bavsound setup and apparently it's 6-8 weeks on backorder and I'll do everything all at once.
Note that the internals are different for HK and non-HK sound.
He's probably going to gut those housings if he's installing the full BAVsound kit. I'm interested in see the final install and review.
Discussion Starter · #13 ·
I'm not certain but I think bavsound makes something different for the HK/non-HK versions. The speakers slot right in to the HK housings with a little bit of glue
1 - 13 of 13 Posts
