Yes, phone streams to device via bluetooth, Device plugs into headphone aux in port in car, then idrive in aux in mode plays anything that would normally play when you have headphone in your samsung.
Connects concurrently with the factory handsfree bluetooth
Sent from my SCH-I510 using Bimmer App
Has anyone had experience with these?:
BMW E60 E61 E63 E64 Bluetooth AUX-IN ADAPTER CABLE Radio Navigation System
http://i.ebayimg.com/images/g/DfsAAOSwHjNWA9nf/s-l500.jpg
http://www.ebay.com/itm/BMW-E60-E61...ash=item3ab36a1705:g:DfsAAOSwHjNWA9nf&vxp=mtr
Bluetooth Aux-In Retrofit cable suitable for BMW models:
from year 2003
BMW 5 Series (E60, E61)
BMW 6 Series (E63, E64)
Allows you to stream your music via the Bluetooth function of the mobile phone / smartphone to your car stereo.
in conjunction with:
AUX must be selected or are to be enabled!
SA 609 (navigation system)
SA 650 (Business radio with CD drive)
SA 661 (Business radio with CD drive)
SA 662 (Radio Business)
Specifications:
Most x 1 connector (12-pin)
MADE IN GERMANY
Plug and Play
Function via Bluetooth-enabled devices
No functional limitations of the car radio
allows you to connect an external audio source
Very easy installation
this module allows you to connect an external audio source such as Spotify on Bluethooth enabled devices (eg. B. smatphone, Tablet, iPad, etc.)
The CD changer function is maintained.
AUX must be activated in the menu!
from year 2003
Specifications:
MADE IN GERMANY
Plug and Play
From reading the description it is clearly an Aux In kit with a bluetooth receiver attached. In the ad it states that Aux would need to be enabled on the car to work, the Aux In is a "dumb" connection that simply receives a stereo signal. So yes, it will not have steering wheel controls or display album/song info on the screen.I don't see anything about steering wheel controls. That's the main thing I would want. I added a Soundbot SB360 to my aux input so I at least have fwd/rev buttons. Replaced the bottom of my center console to add some more room.
That is helpful, you would think the hardware would still be there, have you searched the glovebox and center armrest?
I can't see it being worth much to pull out the aux kit, more work than it is worth! But hey, you never know...
I/m using in my bmw bluetooth adapter from Sound2Air and it works very good for me also you could charge you phone at the same time https://sound2air.com/collections/b...ir-bluetooth-a2dp-adapter-for-bmw-mini-cooper superior quality and music streaming***65279;
