QUESTIONS:
1) What Fault Codes do you have in the FRM Module, the CAS Module and the JBE Module?
2) What Make/Model Scan Tool do you have? Do you have any Diagnostic Software such as INPA/ISTA?
3) What are the Last-7 Characters of your Vehicle's VIN? Needed to make sure correct wiring info provided.
4) Are you SURE it's the Brake Light bulbs (including High-Middle LED panel) that are "flickering"? Is there any regular "Periodicity" or rhythm of lights On/Off, or is it completely random?
5) Do they flicker when Parking/Side Lights are on? Do they flicker with engine running, or simply Ignition ON, either with Side Lights On/Off?
6) Does your Radio Display Panel light flicker (Radio is also powered via CAS Terminal R, along with Brake Lights)?
7) Do your REAR windows work, at least with their respective Door Switches?
The FRM powers the Brake Lights, AND the Front Window Motors, but the CAS provides power via "Terminal R" (which also powers the Radio, and comes on when you insert Remote Key into insert compartment), to the Brake Light Switch to send a signal to the FRM to activate brake lights.
Attached are ISTA screens showing Brake Light Switch and Brake Light circuits for 3/2011 build 323i E90. If you provide answers to questions above we can suggest "Next Steps" to test.
George
2011 bmw 323i (E90); when i turn my car off, all 3 rear lights start flickering! It happens all night and was still going when i checked this morning.
Now my windows no longer work
