1 - 6 of 6 Posts
Hi Bimmerfest folks,
I live in Winnipeg, Canada and am the proud owner of a BMW E53. Recently, I have been hearing this rattling noise when I start the engine. I can't figure it out if the noise is coming from a tension/idle pulley, a worn out belt, or simply the power steering pump. The noise goes away after the engine warms up (roughly 10-15 mins after).
The colder the temperatures drop the louder the noise gets. It gets very cold out here and the temperatures this year have dropped to -30°C (for all you living in the States: -22 °F).
I will attach a video of this issue and hope that you guys can help me get to the bottom of this. Any help is greatly appreciated.
http://sendvid.com/27l2a1kl_a__a2_
My wife's x5 was doing similar it was the power steering. When it got to zero F, whiny grindy moany sound. She was low on fluid and I topped off and it improved.
I saw a heater plug out the front may want to add one to the steering reservoir. If I'm right it makes sense it takes a long time for just friction in the steering recirculating to warm the fluid which will practically be a paste at -30C. Maybe can use something lower viscosity as a possibility.
The groaning sound is the power steering like mentioned previously. You might try changing the fluid to a different type but sometimes when it gets done to -30 or -40 it's going to happen.
1 - 6 of 6 Posts
