1 - 3 of 3 Posts
We just bought our first BMW this past February. I say fisrt because there will be more.
However, last week the p/s started failing.:mad: It was a little low so I added some fluid to bring it up to the correct level. This did not fix the problem. I took it back to the dealer and they say that the pump is bad. It is not making any noises and I was wondering if maybe it isn't the pump. Someone mentioned that there is a check valve. :dunno:
Please help.
I have this same problem; leaking power steering oil due to a bad power steering pump, now off to installed that PST/Pump......mmm
Premium Member
:wave: Welcome to the 'fest.
You should post this in the E46 section. You may get more answer's there.
Best of luck!
1 - 3 of 3 Posts
