1 - 6 of 6 Posts
My one-touch on my driver's side does not work. Is there a specific wire that I need to examine to see if the connection is loose?
Also, my rear defroster is not working. Has anyone else had this problem?
TIA....
BTW -- has anyone ever tried to create a one-touch up switch that would close the windows AND the sunroof with just a push of the button? I know the one-touch close of the sunroof can be done; but, I sometimes wish I could close everything with one-button...:D
fahrer
You might check this out for some ideas on what it's going to take to make a one-touch work.
http://forum.e46fanatics.com/showthread.php?threadid=22353&highlight=pulse+window
You'll need something between the new switch and the factory wiring to contiuously send the "close" signal.
Or you might be able to home-run wiring from the individual switches, but you'd still need to isolate them from each other.
A sudden sense of liberty
TIA....
The convertibles have a switch that rolls all four windows up and down with one touch. I'm sure this could be adapted to the coupe/sedan.
Discussion Starter #4
Thanks guys...
JST - do you have the wiring schematic regarding how they tied all of that together in your convertible?
The only foreseeable problem I think would be the sunroof, having that connected with the one-touch windows.
I also would like to have one-touch open everything as well... heheh......I know, I should leave the car as-is...:)
Re: Thanks guys...
No, but the Bentley's manual is full of wiring diagrams. There may be one in there.
Rest in peace, Coach
One touch window not working is indicative of two things:
1) A malefunctioning pressure strip. Check this forum for a post from VinceTopasblau regarding this. You would either have to adjust the pressure strip or replace it.
2) A malefunctioning switch. Replacement only.
1 - 6 of 6 Posts
