1 - 3 of 3 Posts
Recently got BMW 323i 2000, needs maintenance
My A/C Compressor won't engage, I need help all I have done was the check fuses and they all checked out fine. What else should I check or fix. If all else fails how much to replace the whole system at a repair center.
When I driving I noticed my traction control was disabled, as a light came one for it, I was able to turn it off when the engine was off, but after a 2-3 minutes of driving it came on again, but I didn't notice any loss of traction, so I do not know the problem, I also checked the fuses for that once again and it was fine. So again my problem is that I pressed the DSC button it came off, but after driving it came on again without loss of traction.
I have really squeaky rear left brakes, is it the brakes pad, the reason for this, it sounds like a school bus coming to stop. And how much it cost replace all 4 sets of them.
Thank you for helping solve these maintenance problems, you do not have to answer all of the questions.
Keeping it surreal
1. Read the E46 Wiki, it will be educational
2. Read Dave Zeckhausen`s paper on "Brake Bedding" (sometimes the simple things work)
3. That intermittent DSC light might be caused by dirty or corroded wheel speed sensors. This is a cheap and easy DIY fix, you`ll find a couple of DIY videos on YouTube.
1 - 3 of 3 Posts
