problem with ista d and error
35K views 32 replies 6 participants last post by  bronx
#1 ·
i just install ista d ver 4.24.30 blp 4.24.31,
However i cannot communicate with the car, when i go to:
Operations > Read Out Vehicle Data > Complete identification
I get The vehicle could not be identified successfully. Check vehicle interface and 'PAD active', i use enet cable . cable is ok i checked. but what now... in ediabas of rheingold interface is remote. i dont have and other programs or ediabas on root of c:
1010564
i put ip on network and when i start zgw a recieve another ip in that ratio od addres and communication is ok...sorry if my english bad....somenone help i need ista d for diagnosis....thanks
#6 ·
In ISTA Settings, what is your Vehicle Interface / VCI Config Interface Type set for?
#8 ·
It should be second Option, and then make sure EDIABAS.ini set for INTERFACE = ENET.
#9 ·
i truy and the same problem. i put already enet in ediabas manual open in notepad and change interface ENET. and choice ediabas in ista and same error :(...but look this in ediabas from rheingold, evupath simulationpath is c:/ediabas/ecu, but my ediabas is in c:/rheingold/ediabas not on root c:/
1010587
#12 ·
You used ENET Cable with ISTA/P? Must be very old version of ISTA/P as ISTA/P is now for E-Series ony.
Install run Tool32 and see if you can get it working with ENET Cable. If it can connect, then ISTA should be able to.
#14 ·
If INPA worked with ENET than ISTA should too.
ISTA has it own EDIBAS.ini. Are you setting it for ENET and not your Standard Tools EDIABAS.ini?
#16 ·
Tool32 uses different EDIABAS. Testing with it will only prove Firewall is not blocking and Cable is good.
This is the ,ini that matters for ISTA:
C:\Program Files (x86)\BMW\ISPI\TRIC\ISTA\Ediabas\BIN\EDIABAS.INI
Not C:\Ediabas\BIN\EDIABAS.INI
#27 ·
Hi.
Would anyone be willing to help make Enet work with ISTA D? I tried all the procedures from the forum but without success.
ISTA starts but does not connect to the car (F45). The error is displayed: The vehicle could not be identified successfully. Check vehicle interface and 'PAD active'.
I tried:
Edit EDIABAS.INI (enet)
Edit the registry (online mode true)
Set the IP address in the network adapter settings
Today I installed EasyBMWTools, but even Tool32 does not communicate.
The laptop network adapter is working properly. I measured Enet with a multimeter, it looks OK.
Thanks.
