Programing Failed Esys (!Solved!)
556 views 7 replies 2 participants last post by  shawnsheridan
#1 · (Edited)
Hi
I have a question. Or better say :D What posibility i have when A Flashing ECU I-Level Update fail (E-Sys)? Only ZGW its Updated… Problem that Caused this just because me Psdtz have somehow corrupted and all file inside Like Swfl have 0KB… now i See me Psdtz have 50 GB No 268GB what its supposed to have…. I am right now extracting psdtz so i have time to ask question… but now car its stuck nothing function just Combi Kluster have light on…. Its possible somehow reversed that Flash? i have all files Saved (FA/SVT) Or i Need to wait to new data extrac and then Process that again ? But also Ista have problem read VIN from car i Must put it Manually and then i get Info I Level Cann Not Be Readed from car…
Have you some tips ? What i can do ? Tips for Tips = Bussiness
Many Thanks for you Time and help
Greetings
Johnny
F10 BMW 530DX
! Problem Solved ! With tip from the best one on forum! Me big UP goes to @shawnsheridan !!! Herzlichen Dank or Many Thanks !!! 😍🥳(y)
After I Drive Update gonna wrong because of corrupted SDP in me fall.
You Need to download or extract if you have full SDP files to C://Data and Re-Run Processing TAL with existed FA SVT TLT files Not removing uninstal or whatever just start the proces with Existing files and correct one SDP files and that gonna help you Little Bit from Panic attack 😂🤣😅
#3 ·
:eek::oops: Ouuu wau new in the forum and best member reply coool…. :cool:
Have it done! Thanks…. Now its that 80% better… I have two issue Frist one 5% its some E Call Not function warning i think that can be problem with 2G or whatever… But 15% Also Main Problem its Left Side LCI Xenon have function time E.T.A 10 - 15 minutes… first get light purple and more more more just like loosing xenon light after that Not function at all but when I give them to Position 0 and after that back to Automatic Light function time its another 10 minutes … I am Little Bit confused becouse This one have 8 Months with ECU Unit all its Almost Brand New on the driver side and from BMW Original. Left one function 100% normal and its like 12 years old :D
