PsdzData error on E-sys
11K views 42 replies 18 participants last post by  shawnsheridan
#1 ·
So I recently updated my psdzdata files, I have deleted the old data and copied the new data on hard drive and now i get this error:
The content of the current psdzdata folder "G:\psdzdata" is invalid or empty.
Only data handling modules are available.To use all E-Sys functions without restrictions,
please import a valid PDX container or set a valid psdzdata directory. [G270]
Set PSdZ-Root using "G:\psdzdata" failed! [C073]
Initialization of PSdZ failed due to following reason: G:\psdzdata\psdzdata\mapping\brref.xml file is missing in psdzdata directory.. All previously applied changes during the initialization process will be undone. [2045]
The thing is I dont have data in: G:\psdzdata\psdzdata\ my data is in G:\psdzdata\mapping\brref.xml
I have tried to remove the file location and relocate it but nothing works.
#2 ·
Put entire data folder on G: Drive. Put new psdzdata folder in G:\Data folder so you have G:\Data\psdzdata. Set E-Sys Options for Data directory to G:Data.
  • Helpful
Reactions: davidfx.pacu
#6 ·
i am getting this same error. it is a new install and I have done what is mentioned above. I am still getting the error. see screenshots. where am I going wrong?
thanks
What is size of D:\Data\psdzdata folder?
#8 ·
It shows "D:\Data\psdzdata\mapping\brref.xml" missing. Is it not in your psdzdata?
#10 ·
Then I have no idea. Clearly Esys can't see it for some reason.
#17 ·
For Combox, did you add 6VC to FA and Change FA Build Date?
What is hifi prof? The Amplifier or CIC Head Unit?
#25 ·
Привет, Шон.
не могли бы вы поделиться со мной последней версией PSdZData и E-SYS?
PM sent.
#30 ·
Hello Shawn, I have problem with my esys 3.27.1, psdzdata lite 4.45.10, in edit FDL it show me no EST file chosen [C155] (i want to change system sounds) and I dont know what to do, can you help me with that? BMW f11 2011 CIC
Thank you
#31 ·
Thank you
Update your E-Sys. New E-Sys does not even use an ,est Token. You do need a CAFD Napping solution like BimmerUtilty for FDL Coding, same as old LauncherPRO did. PM sent.
  • Like
Reactions: 5ZV3!
#43 ·
PM sent.
