PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#5,255 ·
As Thread Title, "Fxx-/Ixx-/Gxx-series PSdZData FULL Requests (Programming Firmware)", indicates, it is for PSdZData Full, not Lite.
And i you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full.
PM sent.
#5,257 ·
Hi Shawn,
Excellent resource being using lots of your guides to learn
Can you send me a link to the latest psdzdata full please?
PM sent.
#5,266 ·
#5,278 ·
Wrong Thread. As Thread Title, "Fxx-/Ixx-/Gxx-series PSdZData FULL Requests (Programming Firmware)", indicates, it is for PSdZData Full, not Lite. PM sent.
#5,280 ·
Hi Shawn,
My G20 just did a OTA software update (yes it actually worked!) to 11/2019.70, would I need to update my PSdZData? The version I have currently is 4.21.32
Thanks.
4.21.32 is from 19-11-xxx so you should be fine.
Since 19-11, there was 20-03, and now 20-07, so why just now is it updating to old 19-11. :dunno:
#5,282 ·
Hi again Shawn,
So the OTA update from 11/2019.50 to 11/2019.70 didn't seem to bring any noticeable benefits but it has wiped out all my coding. So I followed the procedure to VO code again but when I pressed Code in the final step I got an error:
File for "cafd_00003e52-006_022_028" not found! [C012]
Reading a different thread thought it could be the PSdZ version?
