PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
This post has been deleted
#583 ·
PM sent.
So you will flash car from 61.3 to 61.4? You update ECU firmware with every new release?
#598 ·
Hi...could you please send me the link for the latest PSDZdata file for my 2012 F10
Thanks very much..I have downloaded everything else but want to make sure I can flash my software to the most recent and best data file
Thanks very much indeed
Alex
PM sent.
#599 ·
So, I obtained all the necessary files, but am not having any luck getting a response from fxxtokenmaster@gmail.com
I provided the Request code and version number a few times via email, but only get the following response:
Thanks for your email. I will respond as soon as I can. Expect delays in my reply.
Launcher Premium version 2.7.0 is the latest, ensure you are using the latest version always.
NOTE: This is an automated response. Do Not Reply to this email.
E-Sys Launcher Premium V2.7.1.135 Request Code: CS1341DC65D4544707
Thank you!!
Any ideas on how I can obtain the activation code?
Thanks !
#600 ·
It can only come from TokenMaster, and he is out of pocket. If you do not run in a Virtual Machine, and you are using Normal U.S. / English settings, you should not need an Activation Code.
#605 ·
#610 ·
#613 ·
Greeting All and ShawnS...
I have a 328i and would like to code a bit this weekend. I have the cables last week.
What is a good link for a tutorial on getting started?
Link and proper version of software to get this done?
How do I ID what version software is currently installed, i assume the shop has done some updates at one point or another?
Thanks and looking forward to leaning and sharing! :thumbup:
-- Deep
#614 ·
I assume your 328i ia an F30 328i. Use latest software and current car version is irrelevant. PM sent.
#624 ·
This thread is about requesting FULL PSdZ (only needed for flash programming ECU's).
Not sure if those are your images, but both are from Older Launcher. Newest no longer requires you to enter path; instead all you must enter is PIN twice. Software will only Generate new token if not already present.
For latest software see OP:
Fxx, Ixx, & Gxx Series Coding: Latest Software, Guides, and Tips
