PSdZData FULL Requests (Programming Firmware)
2 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#6,302 ·
hi Shawn, I'm new to this forum but I can read your spopro posts on the web :). Maybe you would like to help solve my problem. I have a g20 with HK 6U3 etc .. I decided to equip it with DVB-T. I solved the problem of antennas. I have 2 pieces of RAM HIGH with DVB-T - one used, the other new according to the BMW catalog. Rewritten FA by adding 601 (for 60A there is no option). On the used one, everything started and worked great for 2 months, then a problem arose - no TV signal - the rest OK. On the brand new RAM, everything from the TV is fine, it works, but the audio system is seen as stereo, not HK. When I try to flash the RAM it crashes at 70%. Esys tells you to replace the RAM. I spent 30 hours on it and I have no ideas anymore ... Thanks for some tip Regards
