2,941 - 2,960 of 10,885 Posts
Hi Shawn, would you mind sending a link to latest full? Thank you in advance!
P.S. I'm new to BMW, and was searching for the difference between psdzdata full that have version numbers in the 14.x range and others that number in the 63.x range? I understand that there are both full and lite versions of psdz. Thanks again!
PM sent.
BMW Changed F-Series Programming from ISTA/P to ISTA+, so PSdZData version numbers changed along with it.
Hi Shawn, do you have The 5.01.02 psdz files?
Need old one for my 2014 f31. With newest There is a Missing cafd which can Not found via cadf from swe.
Thank you!
No, sorry, I do not keep older versions. What is name of CAFD you are missing?
Hi Shawn,
when i want to read the coding list, i get error C012:
"CAFD_00000794_018_070_003 File for cafd_00000794-018_070_003 not found."
When i want to find CAFs for SWE i get:
"swfl_0000155e-018_120_010" [C111] Die technische EInheit 0000155E konnte in der KIS-Wissensbasis nicht gefunden werden.
I-Stufe car is F020-14-03-502.
Thank you
Hi Shawn,
Thank you
cafd_00000794.caf.018_070_003 is the latest CAFD, not older one, and it is in the latest PSdZData.
But this is not a "Missing CAFD" error in that the CAFD is missing from PSdZdata folder. The error is KIS Database related, which is a comparability issue. If car has I-Step Current (not I-Step Shipment) of F020-14-03-502, this CAFD would be way to new for the swfl_0000155e-018_120_010 firmware. You need to inject older CAFD or flash ECU to latest firmware with current PSdZdata.
