PSdZData FULL Requests (Programming Firmware)
1 reading
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#8,263 ·
Hi Shawn,
i lost my (now somewhat outdated) e-sys and psdzdata recently to a crashed hdd ;/
Would love it if you could send me a link! :D
B
PM sent.
#8,272 ·
I'm trying to code in my trailer module for my F15 X5. I coded K235 into the VO but now I'm having a problem injecting the CAFD into the AAG module... Looks like my PSdZData Lite is not sufficient as I get an error for missing swf1_000020a9-38_000_004, and when checking my swfl folder I see it is empty. Is there a way I can get F025 full PSdZData? Thank you in advance, been working at this all day :(
#8,273 ·
Lite has only CAFD, and Lite is all that is needed for CAFD Injection and Coding. Full needed only for Flashing, which you likely need to do here to AAG, assuming FA is valid. PM sent.
#8,283 ·
Hi guys!
2016 F31 330d driver from Germany here.
A while ago, my car was at the dealership for a recall of the egr-cooler. There, they also updated the i-level of the entire car.
Since, i cannot reduce the egr-rate via tool32. this function has been removed for emissions reasons (vw-diesel-scandal) since, afaik, 2018.
The new i-level now causes, on low loads, sluggish engine and gearbox behaviour, louder combustion noise and increased fuel consumption
because of higher egr-rate.
Does anyone have a link for downloading older psdzdata full, from 2017, so i can reflash the DME/DDE with the older i-level? Torrent also possible.
Thanks in advance!!!
