PSdZData FULL Requests (Programming Firmware)
1.1M views 11K replies 3.9K participants last post by  shawnsheridan
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#937 ·
Hello Shawn,
Can you please send me the link to the latest PsdZdata both lite and full. I know the full is only for flashing but i still use it.
thank you in advance.
PM sent.
#944 · (Edited)
No you don't E-Sys / PSdZData is only for newer F / I / G Series cars. You cannot use with E-Series car. For E-Series you need NCS Expert and WinKFP along with latest SP-Daten files.
#949 ·
#961 ·
Just looking for a small amount of clarification here. I've coded my f56 no issues.
Can i use that same PsDZlite file to code an f10, f02, and f16? What is the process of clearing out f56 history and starting fresh on a different chassis?
Also, are we able to code in the latest Nav versions?
Requesting links to the latest files please. Thank You!
#962 ·
Use same PSdZData. There is no need to clear anything. What do you mean by "code in the latest Nav versions"? If you mean code NBT2 ID5.6, yes you can code it.
#964 ·
I see. I was not removing NCD's. Thank you
By "Code in the latest nav versions" I mean upgrade the maps. Figured here is where to ask before I purchase it.
@shawnsheridan That is not what I meant, but that may be my next endeavor. I will look into it. You mean upgrading the idrive version, correct?
I've seen, in person, a F80 running iDrive 6.0 (lite). Car was delivered with 5.0. If these are the changes you are talking about, any tips on how to get this done?
Any chance you have the files required?
#965 ·
NCD's are automatically downloaded to C:\Data\CAF. So, if you do not first remove, existing ones will either be overwritten or be extras.
IF HU_NBT2 with ID4++, you cannot simply code ID6_Lite. If IDrive5, then you code HU_NBT2 HMI_ID_VERSION to ID6_lite. No additional files needed.
