361 - 380 of 10,877 Posts
Hi again Shawn,
Will highly appreciate the links for the latest PSDzDAta and related Esys version.
Thanks a lot as always!!
PM sent.
... part 11 and 13 cannot be downloaded. There is an ERROR shown.
Work fine for me, and no one else have any problem. Maybe MEGA is just having a temporary issue.
Hello Shawn,
I just started the downloads several times; suddenly no error and now is is going fine.
Thanks.
Regards
AW1962
:thumbup:
What should I do for using new version of psdzdata? It's enough delete and replace this folder? I had v58.3 with esys 3.27.1 and now I need to use V60.
Yes, just delete old psdzdata folder and replace with new one.
Thanks Shawn, I have done something wrong because after that, when read the SVT from VCM I alway see the old version of cafd. With KIS/SVT calculation I see that the car need the cafd 006.020.007 but esys use always the old cafd that I had with v58.3... can I help me?
Why did you think something is wrong? The ECU needs to be flashed in order to use new CAFD.
Can you give me some guide or tutorial in order to do this? If I unistall ESYS and launcher and install again should work? I need the token from token master again? Many thanks
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the latest CAFD as shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
You are precious...last question: today I have made a FDL code (RDC saftey and Startup logo) with old CAFD, I had "broken" something? The code work properly and esys don't give me any type of error.
