PSdZData FULL Requests (Programming Firmware)
1.1M views 11K replies 3.9K participants last post by  sun56
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#9,273 ·
Hi,
I have a 520D 2012 Pre-LCI, I-step: F010-12-03-511 and I am trying to register my new TMS module within the FRM but I think I have the wrong psdzdata version (3.56.3). Using E-sys 3.26.1. Any possibility that I can get the correct psdzdata for my I-Step version?
Am I correct also that I need to use IstaP and not Ista+ for my I-Step version?
#9,274 ·
No. Correct Psdzdata version is any version >= car version, which in your case in from March 2012.
ISTA/P is ONLY for E-Series Programming.
#9,279 ·
@shawnsheridan - I can read coding data in other ECUs in my 2018 F30, but not HU_Entrynav2, which gives me this error.: "File for "cafd_00001ef6-006_064_003" not found! [C012]". I am using PsDZdata v4.36.22 - do I need a later version? Thank you in advance for any help
Yes, update. PM sent.
#9,286 ·
hey guys, im new to the fdl coding. I used a carly obd adapter and throughout coding I don't know if i was gassed or if I have a spare chromosone. The ignition timed out or so I thought and i hit the ignition button and when I started the car my rpm fuel and oil temp read 0. I know as far as much as my cluster needs to be recodded to the ecu but esys has been giving me nothing but headaches, I cant find the download links or if I can they have been removed. Could someone send me the newest version along with the launcher etc please? Also, some advice or a download tutorial pdf would be amazing, thank you in advance!
#9,293 ·
Shawn
Can I get the latest sp-daten files for e64 (E60 chassis)
Using istap to program
Sent from my moto g power using Tapatalk
The thread has nothing to do with SP-Daten. PM sent.
  • Like
Reactions: theflash32
#9,298 ·
Hi Shaun could i please have the latest pszdata ..
as the one i have im getting this message
"The content of the current psdzdata folder "C:\Data\psdzdata" is invalid or empty.
Only data handling modules are available.To use all E-Sys functions without restrictions,
please import a valid PDX container or set a valid psdzdata directory. [G270]
Set PSdZ-Root using "C:\Data\psdzdata" failed! [C073]
Initialization of PSdZ failed due to following reason: C:\Data\psdzdata\psdzdata\mapping\brref.xml file is missing in psdzdata directory.. All previously applied changes during the initialization process will be undone. [2045]"
thanks in Advanced
#9,299 ·
thanks in Advanced
PM sent.
#9,301 ·
Asked and answered:
