4,001 - 4,020 of 10,885 Posts
corrupted fem_body. fffff_255_255. I need to have the full version of the PSdZData file right?
can I get the link please. for F30.
thank you!
Not if that is referring to the CAFD, then just inject new CAFF and VO Code it using psdzdata Lite.
Any clue why button is gray out? Version is the one it should work. 3.27.1.
Injecting CAFD and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher
1) Install E-Sys 3.27.1 to default location, C:\EC-Apps\ESG\E-Sys.
2) Use E-Sys 3.27.1 for normal FDL and VO Coding. For FDL Coding, use E-Sys Launcher PREMIUM 2.x to launch E-Sys 3.27.1,
3) Install E-Sys 3.33.4 to different location, e.g. C:\EC-Apps\ESG\E-Sys_3.33.4
4) Use E-Sys 3.33.4 for CAFD Injection and Flashing. Do NOT use with E-Sys Launcher PREMIUM 2.x.
Can you send link for latest PSdZData full (also G-series), thanks.
PSdZData is for all F/I/G Series. There is not something unique for G-Series. PM sent.
Hi,
I need to update my newly acquired 2014 F12 xdrive. Can you send me the link to download the full pszdata please.
PM sent.
Not sure if this is the place for this but today I was updating my car using ISTA+ version R4.16.22. It was able to update most of the modules but it would not update KOMBI and AMPT and HU-H. Any secrets to do those? Thanks.
Not sure. I don't flash with ISTA myself. All 3 modules are on the MOST bus though. I think you need an ICOM interface if you were not using one. You can always flash them with E-Sys and PSdZData Full, and an ENET Cable.
